Question about ASUS P5B-VM DO Motherboard
My A7N8X-VM Mobo won't power up
The fan comes on briefly and then stops.  Replaced CMOS battery as I did manage to get into setup once and saw that date/ time and other settings were lost but mostly I can't get machine up.  I am open to all suggestions! Some of the solutions I have seen for other mobos seem to suggest a bios upgrade but I don't understand how to do that if you can't power on the machine.
Thanks in advance!!!
  • desperate190 Mar 02, 2009
    This machine was running for about 2 years without issue. This problem just started, no changes were made to the machine prior to the issue starting. I did reset the CMOS, but that did not help.
  • Dick
    Dick May 11, 2010
    Has this system been running for a while or is it a new build?
  • 447 Answers
I do have a question - was this memory functional in your board before or is this a new install/upgrade?
Many times the issue you've described can be memory related. This is a link to the types of memory your board will support - pay close attention to the voltage, if the memory you are trying to use right now has the wrong voltage you will get no post and/or video (and on occasion error beeps).
The other thing you can try is resetting the CMOS (via the onboard jumper which should be near the battery). Instructions on how to do this should be in your mobo manual.
....and of course, ensure that both power plugs are connected to the mobo.
Post additional info or your results back here.
Note: I am not affiliated with the company who's link I've posted, it's for illustrative purposes only.
Posted on Mar 01, 2009
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
I'am working on ASUS P5PE-VM mobo, I removed the memory, video card and isolate the mobo away from the casing so no short circuit may occur during test. I plugged in the power supply and the front switch...
HI,
Clear CMOS or remove CMOS battery, Press the on off switch for 30 seconds.
Now go to BIOS setup,and set bios fail save default,and press F10>enter.If the problem same change the RAM if you have a spare.
http://www.computerhope.com/help/phoenix.htm
Hope it helps.
Jan 13, 2011 | ASUS P5PE-VM Motherboard
I have ASUS P5VD2-VM SE - Motherboard when i turn off power supply and start my pc again, it display a messege always "Cmos Checksam bad date and time not set" I replaced old cmos battery with...
Oh, you need to go into your BIOS, for that Motherboard, you should press alt+f2 while it boots up and that should load you into BIOS (or it might be called Setup). Once you're in there you need to change your Date and Time to the current date and time. Hope that helps!
Dec 14, 2010 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
PC gets to "Starting Windows.." then suddenly restarts.
you may want to reinstall your operating system i know several people with this issue and it has worked fine just insert the cd of whatever os you choose then boot from it
Dec 24, 2009 | ASUS A8V-VM Motherboard
Normal shut down on pc, now it will not power up.
if you can figure out what pins your power switch is plugged into you can try and bypass the switch as for the power supply itself i know theres a way to trick it and boot just the power supply but i cant remember what pins on the plug it is try and google the power plug layout it should tell you what pins to connect to boot it
Oct 28, 2009 | ASUS A7N8X-VM Motherboard
Motherboard power problem due to atx 12v cable
I tried different power supply but its still not powering up. But when i remove the 4 pin 12V cable from power supply the cpu fan is rolling, it means that the power supply is working but when i tried to connect the 4 pin then the cpu fan stop just a second and never rolled on. The main problem is the 4 pin, the model is Asus P5P800-VM. I tried to reset the cmos and replaced the battery but it wont work out. Please help me!!!
Jun 09, 2009 | ASUS P5P800-VM Motherboard
PC with poss ASUS A7N8X - VM motherboard problem
Can you give me motherboard & pc infoinfo, the symptoms certainly suggest mobo failure
Dec 02, 2008 | AMD ASUS A7N8X-VM/400 Motherboard
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
No power up
Here was the fix for me. The machine refuses to boot if the video card is not functioning. It should have one long beep however to tell you that there is a video problem. Someone hooked up our speaker incorrectly though! So we got no beeps. Once the speaker was hooked up and the video card was replaced, all is well!
Oct 23, 2006 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P5B-VM DO Motherboard Logo
160 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
