Question about Dell Dimension 4600 PC Desktop
Dell Dimension 4600 will not reconize cd or dvd drive
I have updated the bios switched the ribbons and the cd to a dvd drive
it will not reconize either a cd or dvd drive in the bios or windows
  • 3,940 Answers
  1. ensure the drives are jumpered Cable select.
  2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
Posted on Mar 01, 2009
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
Dimension 4600 does not recognize cd/dvd drives
Open the computer, and check if the cables that go to the CD/DVD drive are connected. If so, try downloading and installing the drivers for the disc drives. I hope you get it fixed!
May 28, 2012 | Dell Dimension 4600 PC Desktop
Where is the hard drive?
Turn the computer off.
Disconnect the AC power cord.
Remove the side-cover.
Look for one or two 1/4-inch-wide RED cables running from the motherboard to some device, namely your CD/DVD and/or your disk-drive.
Or, look for one or two very-wide "ribbon-cables" running from your motherboard to some device, namely your CD/DVD and/or your disk-drive.
Oct 28, 2010 | Dell Dimension 4600 PC Desktop
I can't boot up normal, safe mode, or to the cd-rom on my dell dimension 4600 desktop, i've set to boot to cd rom in bios, but still nothing
If you are trying to boot off an Windows Installation disc then you might have a problem. On some computer the CD-ROM drive won't be able to read the operating system disc.
The solution to this issue would be to put in a DVD drive and try to boot from that.
More details on the normal and safe mode boot attempts would be nice too. Are you getting a blue screen or is it just hanging up?
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension XPS GEN 5 IDE Philips CD DVD drive failed. So I tried a Liteon SATA CD DVD drive, but that wouldn't work. So I tried a Samsung IDE CD DVD drive and that won't work. I'm guessing mobo driver...
first try installing one and go to your bios and set your bios to default . save you changes and exit.
also in my computer look and see if it appears there
if so you know its being reconized.
rite click it go to properties and then hardware
select the drive if you have gotten this far meaning you saw the drive. . go to properties and see if it says its working properly. it could also be that none of the drives your trying to install are compatible.
Nov 12, 2009 | Dell Dimension XPS 400 PC Desktop
My Dell Dimension 4600 does not recognize my CD burner and DVD pl
Yes, try replacing the cable and make sure the power connectors are all the way in
Oct 08, 2009 | Dell Computers & Internet
Replacing a cd drive
The 4600 has PowerDVD to play DVDs (You should have the software CD to install it on the 3000) DVD burning software would be Roxio/Sonic, and you should have that CD too.
If you don't have the CDs, then try download.com to download Free player software and Burning software
May 25, 2009 | Dell Dimension 3000 PC Desktop
My dell dimension 4600 will not boot from cd drive first
Go back to the Dell BIOS screen and change all setting back to the default settings. Put in a Bootable CD and press F12, this will give you boot menu. Then you can boot to any device that you need to.
Please rate my response
Feb 17, 2009 | Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Dimension 4600 cd/dvd drives not responding
Try uninstalling them in devive manager then rebooting and see
if they are reinstalled automaticaly as drivers should be in xp already.
Just right click on them and select uninstall.
If that doesnt work then try update drivers and let xp search online for them.
Failing that then try changing the cable thats attatched to the motherboard.
Hope that helps? :)
Jan 04, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
249 people viewed this question
Alun Cox
