Question about Whirlpool Water Heaters
Pilot will not stay lit
Heater is less than one year old. I think it needs a new thermocoule but don,t know how to change it with new enclosed panel
  • 50 Answers
Brand might help evaluate problem. Thermocouple with FVIR housing is hard. Might try the original installer and Mfr too as for some (Whirlpool esp) the pilot connector is dedicated and won't take the universal Honeywells). Also be sure what type you have..Powerpile, etc.. Mfr may send you one under warranty but it'll take a week to arrive.
Good news is if it's a Whirlpool from American, you'll be changing it yearly. Do and online search and you find out it's a common problem with some brands
Posted on Mar 03, 2009
Pilot light wont stay lit once button is released unit is about 11 years old
call your plumber and have it serviced possibly just needs the thermocouple replaced .
Dec 28, 2015 | Bosch & Tankless LP Hot Water Heater
Rheem rp4036m
Under the gas valve is a removable panel. On models of that era there should also be a second panel behind the first. remove both.
the pilot light should be clearly visible.
If no pilot, turn the gas valve to OFF. wait 60 seconds. locate the tubes from the gas valve to the pilot location. turn the valve to pilot, and with a long match or grill lighter lit, place flame at the pilot location and press down on the pilot button beside the main valve.
pilot should light. If not shut off the gas and call a technician. If yes, hold the pilot button for 60 seconds, then slowly release. Pilot should stay lit. If not, shut off gas and replace thermocouple, start relight sequence over. If pilot stays lit, replace inner cover and adjust temp to 120 deg. If heater fires up, replace outer cover. Done.
If heater does not light, replace gas valve or entire unit. Water heaters have a limited life expectancy, and if my recollection is correct your unit is 10yrs past warranty.
Dec 04, 2013 | Water Water Heaters
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Aug 16, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
My 1.5 yr old gas water heater has a pilot light problem
YOUR WATER HEATER HAS WHAT IS CALLED A STANDING PILOT-STAYS LIT ALWAYS WHEN THE PILOT GOES OUT YOU LOOSE EVERYTHING. YOU HAVE TO REPLACE THE THERMOCOUPLE WHICH KEEP THE PILOT LIT. ONCE THE PILOT IS LIT THE THERMOCOUPLE SENDS IN MILLIVOLTS TO THE BURNER TO SAY ITS READY FOR BURNING
IF YOU ARE NOT FAMILURE WITH THIS REPLACEMENT PLEASE FIND SOME ONE WHO CAN. IT IS NOT HARD TO DO ASK A NABOR OR FRIENDS SOME HAS TO KNOW HOW. SERVICE COMPANYS ARE OUT FOR THE MONEY FOR A 10 MINUTE JOB
Aug 10, 2009 | Water Heaters
I don't know how to restart my old bosch water wizard 10p, pilot light has gone out.
get a long stick match, a flashlight remove lower inspection cover, find thermocouple and pilot light will be next to it,turn gas valve to pilot light and hold down,stick the match in by thermocouple till the pilot lights and hold valve down till pilot stays lit,this may take a minute or more,then release gas valve and see if pilot stays lit, if not retry,if it wont stay lit,the thermocouple is defective and needs replacement
Jul 12, 2009 | Bosch & Tankless LP Hot Water Heater
Gas water heater kenmore model pilot will not stay lite
I have the same problem. Water heater operates on a very simple principle. of thermo-mechanical feed-back and response. In my case, I have a Kenmore Power Miser 6, NG heater with an electronic pilot ignition system. The heater is just over one year old and last month (conveniently just after the 12 month service warranty expired) the pilot light started extinguishing on a very regular basis. I find it interesting that the very problem I am experiencing, is happening to other Kenmore owners (victims). The solution can be found in replacing one of two possible components; the pilot assembly or the gas valve manifold. The price of DIY pilot assembly replacement is approx. $60 . The valve component is significantly higher. Water heaters are designed and built to provide years of trouble-free reliable service. This is the first Kenmore product I have owned. From a customer perspective, with regard to product performance, Sears/Kenmore needs to take a strong look at their supplier quality. Oh, by the way, contacting Sears for remedial relief only managed to frustrate and infuriate me. You see, I am in Quality for a world-class aircraft company. I understand what ethical steps are required to satisfy a valued customer. I plan on ripping out the defective unit this weekend and replacing it with a reliable Home depot special. At least with HD, if the heater fails to perform , I can return it. Hey Sears in Chicago, don't come crying to the consumer when you are looking for the trendy "bail out". Signed- "Burned Out" in La Habra, California.
Nov 08, 2008 | Water Heaters
Water Heaters Logo
161 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
