Rheem LX2000 intermittent start problem
We have a Rheem LX2000 model RGRAO6EMAES with a White-Rogers 1F80-361 thermostat. Lately furnace will not kick in after temp. drops several degrees below the trigger point. When I look at the PC board the ''PWR'' light is on but the ''OK'' light is flashing. If I turn the furnace power switch OFF and then back ON, the furnace will fire up and run properly for a day or two.
How much btu is the lx2000 reem furnace or how much tonage
Posted on Apr 22, 2009
    Problem Solver:
  • 5 Answers
Check all wires are tight and good on both ends if you are not a sparky then turn it off first at the power box
Posted on Mar 02, 2009
LX2000 gas furnace. It starts and runs for about 5 seconds, then why does it shut off?
Fix Furnace Flame Sensor (Flame That Goes Off) - YouTube
? 1:22
https://www.youtube.com/watch?v=fBJ3r9MUa-U
Nov 29, 2011 - Uploaded by RochNoure
A Furnace Flame Sensor is a safety device that reads the temperature and ... easy fix, but the furnace is ...
Troubleshoot the ignitor of the Rheem RGDA model gas ...
? 5:53
https://www.youtube.com/watch?v=Bx1pXONg2Oc
Dec 12, 2012 - Uploaded by grayfurnaceman
Troubleshoot the ignitor of the Rheem RGDA model gas furnace.... Jun Sim 5 months ago ... My lennox ...Missing: lx2000
Rheem Criterion II No Heat - YouTube
? 0:47
https://www.youtube.com/watch?v=yOSk6qvpWbA
Jan 7, 2010 - Uploaded by Work12Progress
Rheem Criterion II gas furnace model # RGPH-07EAMGR. When a call for heat is made t wo green led's ...Missing: lx2000
Heater will not kick on unless... [Archive] - Self Help Forums
www.selfhelpforums.com/archive/index.php/t-2153.html
Oct 19, 2004 - 25 posts - ‎9 authors
After a certain amount of time of not running, the heater will refuse to kick back on. ... 2 flashes, then a 2 second pause = pressure switch is open. What do .... On LP gas furnaces, the spark starts and the gas valve opens. ... Buffing them up with a little steel wool (5 minute job) is a good annual PM thing to do.
Dec 16, 2015 | Heating & Cooling
Why is my 95% rheem furnace blinking code 2
Check condensate water /drain stopped up. It will allow a start after a reset but then it shuts the combustion air fan down and that shuts the unit down this will require a service tech make sure their familiar
with 95% units
Oct 19, 2012 | Rheem Gas Furnace 60000 Btu 95% Afue. Rgrc...
Furnace blower fan problem
Hi check out the fan control switch could be dirty itsounds like this is nit cutting to let fan run also check setting fan off fan on , temp rise and fall
Feb 06, 2010 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Dec 28, 2009 | Honeywell CT3200 5-2 Day Electronic...
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
I have a Rheem Gas Furnace with an old analog thermostat (Wires conneected to terminals R and 4 for the thermostat). I went to install a Rheem digital and programmable thermostat and it indicated that it...
if you have 2 wire at thermostat Terminals at furnace that the thermostat wire attach to should be R & W if your new thermostat has R & W terminals is should work, an easy thing to remember is the red wire on R the white wire on W. If 4 wire at thermostat at furnace green on G, Blue on Y, red on R,and white on W same at thermostat If these do not match find a thermostat with these terminals
Dec 06, 2009 | Heating & Cooling
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
My furnace works intermittently.
You may have a dirty flame sensor. There are a number of other possible causes as well. Rheem/Ruud/Weatherking furnaces also have problems with the connection on the blower deck.
The flame sensor sometimes must be bypassed around the MOLEX CONNECTOR in the deck due to humidity.
Hope this helps.
Matt
maxhtcl1@verizon.net
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
539 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
