Question about Briggs & Stratton Garden
Engine runs for 2to5 mins then stops as if no petrol.Will restart
Engine starts no problem but will only run for between two and five minutes. Then the engine stops as if no petrol. The engine does restart but again will only run for a few minutes.
short shadey
  • 421 Answers
SOURCE: SAAB 900 s 1997
you should check your fuel pressure and be sure it is within spec, is this a 2.0T or a 2.3 non turbo and also this is fuel injected correct? same as the U.S.A. 97 saab 900s? if it is a 2.0 with direct ignition try changing out the DI cassette with a friend or junkyard unit to see if that solves it -Jeff also please rate
Posted on Sep 13, 2008
  • 674 Answers
SOURCE: periodically the car won't start.
let me know if you dont get a good answer
later paul
Posted on Nov 11, 2008
  • 1990 Answers
SOURCE: i have a 1999 intrepid that wont stay running after a few min.
it sounds a lot like the Timing is off. I would locate an Authorized Mechanic to set the Timing.
Posted on Jan 24, 2009
  • 353 Answers
SOURCE: engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Posted on Jun 20, 2009
  • 33 Answers
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Posted on Jul 04, 2009
I have a Miller blue star 3500 with electric start Honda engine.
Have you stripped and cleaned out carburettor?
sounds like a blocked idle jet?
Dec 27, 2016 | Miller Welding Tools
Engine starts,runs good 10 mins. cuts out.wont restart til cold.i suspect coil pack.
Could also be the condesor that is temperature sensitive and most likely cheeper to replace
Mar 01, 2014 | Solo Garden
There are petrol at the inlet of the carburator, the float is fine but no petrol inside the carburator. Engine starts when fuel is added to carburator but lasts for about one min and stops.
there is a blockage in the carb. you really need to pull it apart and clean, use carb cleaner which is a water repellant if available. i am presuming petrol is flowing from fuel pipe ok.
Mar 07, 2013 | Motorcycles
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
I am having problems with my sable cutting off after driving a while then shutting the engine off for aprox 5 min. and restarting. I have pulled the codes up and get a 0191 code, refering to the fuel
try leaving the petrol cap loose then if still no joy answer this post and take it from their ,could be something wrong with the tank vapour thingy .
Jan 30, 2012 | 2003 Mercury Sable
1997 Mountfield 21" Emporer Petrol
check the FUEL plug. when unscrewing the fuel bowl it is the nut holding the bowl on. It sounds like it may be clogged
Jul 17, 2011 | Garden
I bought an ariens 932027 ST724 W/ 7HP Tecumseh HSK70 130266S Engine. It seems to have a problem running for longer period of time than 5 or 10 min. after that it starts back firing and shuts down. It will...
Almost certain, having had this problem with this mower several times, that your petrol cap which is suposed to let air into the tank does not. after a few mins of running suction develops and the engine stops. you check the fuel level and its ok so you restart and it goes fine for another 5 min. by removing the petrol cap you let air in and temporarily fixed it. Clean out the arangement of screws and springs and filters under the fuel cap.
Dec 28, 2010 | Sport & Outdoor - Others
My AC stops every five minutes and restarts after a while.
i hanve 1.5 ton window air condtioner.compressor of a.c runs for 2 min and he it cuts off after 3 min it again starts
Feb 17, 2010 | Samsung AW1293L Air Conditioner
Starts well,runs wellfor five mins but then cuts
My first guess would be the fuel filter. It is probably almost completely plugged.
Oct 23, 2009 | 1991 Volkswagen Passat
My 2001 Chevy Tracker quits running after a while and will restart after about 10-15 minutes. It originally runs rough after it restarts. I have been told to replace the camshaft sensor. Also, when I...
Had the same problem with my tracker. Replaced the camshaft position sensor(easy to do yourself, takes about five mins.) Now can drive at highway speeds for about a half hour and stop at the gas station and she'll start back up and run fine. Before i had to wait at least 15-20mins before she would start. Also, if your service engine soon light is on take it to the national chain auto parts stores and they will hook up the code reader for free. The sensor runs about $120.
Sep 26, 2009 | 2001 Chevrolet Tracker
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
