Question about Maytag Atlantis MAV8551 Top Load Washer
Wet clothes after final spin cycle
Washer is really loud at final spin cycle sounds like its gonna take flight!! now it wont spin clothes out fully at end of cyle even if put on spin again.
  • 2 more comments
  • bsyarman Mar 01, 2009
    washer doesnt spin but will let most of the water out but you can tell that it never started spinning
    doent spin at final spin cycle but water will drain and clothes are still to wet to put in dryer
  • sitruc2000 May 11, 2010
    Does it even spin in that cycle? Is the water being pumped out or just retained in the washer?
  • George Kircher Nov 19, 2012
    I am having the same problem. My washer would go into a super hi speed mode at the end of the spin cycle. It sounded like a jet engine moving up to speed. Now it does not go to that speed any more. If you find the problem let me know and I will do the same
  • 46 Answers
There are two speed (or three) on most washer motors and what happens is that a motor speed will stop functioning--it will wash the clothes, but the high speed will not function. This also could be the controller, but more likely it is centered at the motor. It the motor is functioning, it coulfd be in the transmission of the machine--which may be the problenm since you heard a loud noise. I am not familiar with your machine, there could be an electronic switch for the transmission to go into high speed as well that has gone bad. I wish I had more direct knowledge of your machine.
Posted on Mar 01, 2009
I still use this washer but at the end of the final spin, the clothes seem to come out very wet, What is the cause?
Older washers have an adjustable clutch for the spin cycle.
You would have to look up your model.
Apr 26, 2016 | Washing Machines
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Clothes washer will not finish spin cycle.
maybe something in the drain pump take bottom panel remove pump by turning filter and remove debris dont forget to vacuum out water from drain hose or your gonna get really wet.
Feb 21, 2010 | Washing Machines
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Still wet clothes
It sounds like the high speed of your motor is not functioning which tells me it is either burnt and needs to be replaced, or that the control dial is malfunctioning. Because those motors have two or three speeds, usually one of the speeds of the motor is malfunctioning. Always check connections too, and see if it functions in the spin on another cycle. Best of luck. C
Mar 01, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Clothes still wet after final spin cycle
It sounds like you might have a broken belt or the belt just slipped off the pulley!
Jan 22, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Atlantis MAV8551 Top Load Washer Logo
369 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
