Question about Canon I900D InkJet Photo Printer
How do I Removie and clean the print head on i900D
I have run the cleen print head time after time and black is still clogged.
  • rayikenberry Mar 02, 2009
    I have finally removed the print head and cleaned with a water solution. Put it back in the printer, ran a print check and the Blk6 line will not print anything except a light intermittant line not evenly filled in. All other colors work fine
  • Leroy Elliott
    Leroy Elliott May 11, 2010
    Welllll, DUH
    Genius:
  • 2,120 Answers
REPLACE IT WITH A NEW ONE
Posted on Mar 02, 2009
Not printing black
Sounds like the print head needs alignment. If an "auto" alignment can't or won't be run, somewhere in the maintenance section of your printer driver software should be an operation for running a print head alignment and doing adjustments to get the printer aligned for clear printing. First you should check the maintenance program for "head cleaning" and run a couple of head cleaning cycles to see if a clogged head is the problem...
Jan 28, 2013 | Office Equipment & Supplies
My brother DCP 165c printer does not print black ink, colored are okey. nothing is seen in LCD about this error
If you do not get an error in the LCD screen, it usually means that your Print head is clogged: try running a couple cleaning cycles using your printer inbuilt utility to try to 'clean' the Print head.
If this does not clear the clog head, try using a new original Brother black cartridge (which contains special solvent to prevent clogging) and repeat the cleaning cycles a couple times again.
If the problem persist, you could try buying a print head cleaning cartridge to 'dissolve the dried up ink' as Brother inkjet inbuilt print head are very difficult to access and clean!
Hope it helps & good luck!
May 01, 2011 | Office Equipment & Supplies
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I just replaced the Yellow and the Photo Magenta cartridge in my Canon i900D printer as the computer advised. However, now my photos are coming out with green hair, lips and the other colors are not...
I would first try cleaning the print head, it is possible that print nozzles are clogged and simply not enough ink is able to make its way onto the media.
If the nozzle check page looks good I would try printing some full bleed color pages and see what it does, it is possible,but not likely, that there is either a air bubble in the ink system that could prevent ink flow. If this is true there should be a function for "priming the print head" and it should solve the problem.
Good luck.
Mar 18, 2010 | Canon Office Equipment & Supplies
Color not printing correctly on canon i900d
Take the cartridges and print head out. Pour about a centimeter of boiling water into a saucer or shallow bowl and set the print head in it for about 30 seconds. Place it on a folded up paper kitchen towel for a minute to dry and replace print head and cartridges in printer. Run two normal cleaning cycles and a nozzle check. If the test print is still poor or has not improved at all, the print head is probably dying and it is time to find a new machine. If the print has improved but not perfect, just repeat the process a couple of times.
Dec 11, 2017 | Canon I900D InkJet Photo Printer
Printer
Maybe you mistyped? Is it 'head or 'header'. I believe it is head you want to say. In that case your printer requires a new print-head to be installed.
Your printer has separate ink tanks and heads for printing. The head has a limited life although it works for along time.
The printer should indicated which color head needs to be installed. Try cleaning the head with the printer software first.
You can purchase the head of that color (or colors if more than one) and follow the install procedure in the printer manual.
If you also want head installation instructions, please take some time to post it as a separate question. I will try to give complete instructions.
Oct 12, 2009 | Canon I900D InkJet Photo Printer
Printer will not use the magenta color
I had the same problem. It is most likely that your print head nozzles are clogged. Your choices are to attempt to manually clean them, or order a new print head from Canon.
Attempt the manual cleaning at your own risk, this doesn't always work. When it does not work, it means your print head is damaged.
To maually clean the print head. Printer cover up (so you can get to the cartridges and print head). Turn the Printer Off. Remove all the cartridges (I put each cartridge in a separate zip lock bag). Then flip up the lever and remove the print head.
Now heat (don't boil) distilled water (Iused a good sized cook pan and a plastic measuring cup to pour the water). Find a container you can soak the print head in (I used a deep alluminum baking pan). Pour the hot (not boiling) distilled water over the print head molding where the cartridges seat down (hold the printhead over your diposable alluminum pan). Then dunk the molded print head part into the pan numerous times. When the water gets dark change it (be carefuill not to stain the sink). Then slowly pour the hot distilled over the print head (opposite side from where the cartidges seat in). Eventually no ink will be in the water. Set the print head on a dry paper towel, and let it dry for 24 hours or longer. Reinstall the print head, then the catridges. If it worked, your true colors will return. It make take up to 15-20 photos to get all the ink catridges flowing-be patient. You can also just wait 24 hours after re-installing the cartridges, and hopefully it will take less photos to see the correct color match.
Never keep printing when a cartridge is low or out.
Print a few prints every week. Not printing for weeks causes the printheead and the ink flow to clog!
Good luck. I just recovered my S820 and my i900D using the above cleaning method. Like everything else, your mileage may vary! It cost me $1.29 for distilled water and about an hours worth of time!
Sep 26, 2008 | Canon I900D InkJet Photo Printer
I900D cannon printer
I was having the same problem and I put the printer through the head cleaning and auto head check and it now seems to be working fine.
Aug 28, 2008 | Canon I900D InkJet Photo Printer
Not printing anything in black only the other colours... I have cleaned, and re-cleaned, checked nozzels, changed cartridges done all the troubleshooting hints and still nothing. It's only black that's not...
Hi Alcadeus here just a quick tip if you take out all your ink tanks the print head cleaner lift out easily dont worry it goes back easy believe me. On the bottom you have two strips they are the actual heads, you need to cleen them preferably with alcohol i had none so i used aftershave. Then re-assemble the unit and do 2 deep cleans hey presto problem solved.
Worked for me!!!!!!!!!!!!!
The reason why is the heads go dry or get clogged.
Feb 14, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon I900D InkJet Photo Printer Logo
675 people viewed this question
old marine
old marine
