Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Profile XL 1800 Microwave overheating?
Last week while cooking something on high for 12 minutes the microwave *died* at the end. No power, no lights...dead. I unplugged it when I noticed it felt very warm. The next day I plugged it back in and it reset, but now it makes a rattling/whining noise and still gets very warm so we are afraid to use it.
Does it need a new filter? Something more? Why is it whining?
What could it be?
Thanks
  • Anonymous Mar 02, 2009
    IT IS DEAD, NO TURNING ON ANYMORE
  • William Miller
    William Miller May 11, 2010
    The magnetron probably overheated and caused
    the magnetron thermostat to open.
    Then when it cooled, it
    closed the circuit and allowed power through again.
    You first need to make sure that your internal cooling fan is running.
    When I say internal
    cooling fan, I do not mean the hood vent exhaust fan which you can turn
    on and off manually.
    I'm instead talking
    about the internal fan which comes on automatically whenever you
    microwave.
    We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
    It is vital that the
    cooling fan runs, or the magnetron will be destroyed.
    In some cases, the cooling fan's blade will become loose on the motor shaft so that even though the motor is running, the fan is not blowing.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    Once you look this over, let us know what you find and we'll take it form there.
Ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Posted on Mar 08, 2011
How do I set the power at 50%?
After first setting the cook time---then hit the power level button and hit the number 5 (for 50%) and then start. Power level can also be changed while running by hitting power level button and selecting 1 through 10. For example level 3 is 30% for defrosting.
Mar 20, 2015 | GE Profile Spacemaker XL 1800 36"...
I have a microwave GE spacemaker XL 1800 that stopped working. None of the touch control panel buttons work. Is like death. Is it a fuse? if so how expensive is it?
probably fryed the magnetron, with something like foil or metallic, try unplugging it for 12 hours maybe it will reset if not throw it out
Jan 28, 2014 | GE Profile Spacemaker XL 1800 36 in....
My GE 1800 microwave turntable has stopped turning
There is a motor underneath the microwave that rotates the turntable. The motor may not be getting power or the motor may have failed.
Feb 11, 2013 | GE Profile Over the RanMicrowave....
Ge profile spacemaker 1800 xl microwave no heat
The magnetron tube may have died. Not worth repairing unless under warranty.
Feb 03, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
A key question is does the light and turntable inside operate--if they do suspect a bad diode used in many models, a inverter board (power for cooking) and or the major part a Magnetron.
12_11_2012_3_01_03_pm.jpgTypical diode used in microwaves---it should not read shorted from one end to the other.
12_11_2012_3_02_24_pm.jpgTypical Magnetron--can look fine and not a real way except by replacing to know if good or bad.
The inverter board if there will connect to the above part in some way directly.
Dec 11, 2012 | GE Profile Spacemaker XL 1800 36"...
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
Ge profile space maker xl 1800 shut down during cooking
Unplug unit..reset circuit breakers..check agin and then see if it starts up. It may need drying out due to excess steam
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile spacemaker xl 1800. recently changed a
It sounds like the main transformer has failed. It would be cheaper to replace the whole microwave than repair this one. Sorry to be the bearer of bad news. Hope this helps. Good luck.
Mar 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We have a GE Profile Spacemaker XL 1800. It began making a laboring noise and stopped cooking at the same time.
Sounds like the Magnatron or the HV Cap or diode is failed. Process of will show you which one. Very dangerous area to work in, not for the untrained. Eric
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,882 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
