Question about Texas Instruments BA-35 Solar Calculator
I purchased a SI8838 8 digit solar electronic calculator. I worked the calculator for about five minutes and then turned it off and left it sitting in front of my computer. Could the magnetic field from the computer cause the calculator to fail? The calculator is now completely dead. Jan dorejrh-mail@Yahoo.com
3 Suggested Answers
SOURCE: Ti-84 plus silver edition will not turn on or off except when Ti-Connected
First try to copy all your programs from the calculator to the computer and then delete all ur files in the calculator and download the files back on to your calculator.
Posted on Dec 19, 2007
  • 233 Answers
SOURCE: my ti36x solar calculator is
Try putting out into full light or very near a light source and hitting the "On/Clear" button. Make sure the solar cell at the top of the device is clean. You can wipe it off with a damp paper towel if it has a lot of gunk on it.
Posted on Mar 01, 2011
  • 7993 Answers
SOURCE: Texas Instruments TI25X SOLAR Calculator didgets not all showing
Even if there is an issue with the calculator it is no longer relevant because it is a discontinued product. It does not have a backup battery and it only uses Solar Power. I suggest to expose the panel to sun light to fully activate the display. And then again it may be just old age, and it is time for you to get a more powerful calculator.
Posted on Jun 15, 2012
How to switch off my casio mj-100d calculator
I think this is a solar calculator. On many solar calculators, there isn't an off button. You just stop using it and after a set period of time (6 minutes for this calculator), it turns off by itself.
Good luck.
Paul
Sep 12, 2015 | Casio Office Equipment & Supplies
Number does not appear
Batteries may be depleted. If calculator uses Solar power, expose the solar panel to daylight. On the newer Casio, contrast can be adjusted. Press SHIFT MODE (setup) and look for <CONT>.
Nov 03, 2013 | Casio Electronic Scientific Calculator...
Jun 14, 2012 | Texas Instruments TI-25X Solar Calculator
How do i enter 46degrees 15minutes into my ti-36x calculator?
Enter DMS (Degrees/Minutes/Seconds) values as D.MMSSs, using 0s as necessary:
  • D degrees (0-7 digits)
  • . decimal-point separator
  • MM minutes (must be 2 digits)
  • SS seconds (must be 2 digits)
  • s fractional part of a second
For example, enter
  • 46° 15' as 46.15.
  • 179° 9' 2.54" as 179.090254, note the 0s in front of the 9 and 2.
Before using a DMS value in a calculation, you must convert it to decimal with [2nd] [>DD].
Jan 13, 2011 | Texas Instruments TI-36 X Solar Calculator
My HP 10s Scientific calculator does not switch on what could be the problem, is it maby because the calculator was left in a drawer and now the batery ran flat hou can I charge it on the solar power...
You can't charge the calculator off the solar power panel. The solar power panel merely conserves battery power when using the calculator in a bright environment. Try putting in a new battery and see whether the calculator turns on.
Aug 25, 2010 | HP 10s Scientific Calculator
New Battery???
Try to expose their solar panels to direct sunlight (10 or 15 minutes), just to see if they come back to life.
Hope it helps.
Jun 23, 2009 | Texas Instruments TI-15 Explorer...
Lower half of numbers gone
The only solution which can be tried is replacing the battery.
Goodluck.
May 06, 2008 | Texas Instruments TI-36 X Solar Calculator
Dec 14, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments BA-35 Solar Calculator Logo
116 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
