Question about LG LDF6810 Built-in Dishwasher
Manual for ld2060sh
Hi i am trying to download a manual for dishwasher ld 2060sh iv bought it and they didnt have the user manual can you send me in the right direction please ?thanks Ally
  • 10 Answers
SOURCE: LG LD-14AW2 (03 error)
agreed O3 is not a LG error code. OE is more likely and if so it could be the main pcb faulty, a blocked drain pump or a blocked spigot under the sink where the drain hose connects onto.
take care.
Posted on Jul 22, 2008
  • 171 Answers
SOURCE: LG Dishwasher LD 2060SH OE Error code Draining problem
Hi sonicmule,
I'm Harvey the Master Plumber.
Your question is: Re-circulation pump was replaced under warranty after 7 months. Now there appears to be draining problems. hose not kinked and filter seems clear - I guess the pump is either broken or something has jammed it. Does anyone know how to get at it??? Warranty has expired and a new pump + fitting is gonna be expensive. Any tips?
If the motor runs but it won't empty then the pump needs replacement. If the unit washes but the motor won't come on to empty then you have a control problem. Either way I don't recomend this repair to the average homeowner. The unit must be removed to access the pump. You might consider utilizing our Repair Directory to find a repair man.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: LG Full size silver Dishwasher Model : LD2060SH
IF THERES NO WATER COMING IN REPLACE POWER BOARD
Posted on Oct 25, 2008
rylee_smith
  • 8619 Answers
SOURCE: Hi, I need a manual for LG LD2131 SH
Hi
Thanks for using FixYa. You can download the user manual for your dishwasher from this link--
LG LD 2131 SH Dishwasher User Manual
Please revert for further assistance.
Thanks
Rylee
Posted on Jul 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: my LG model LD-12AS1 dishwasher will not drain, please help
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 08, 2009
Testimonial: "well done"
I NEED A USER MANUAL FOR A LG INTELLO DISHWASHER LD-2050SH
Simply click on the following link which will take you to the PDF downloadable users manual.
http://kitchen.manualsonline.com/ex/product/headline/m/lg/d/dishwasher/p/LD-2050SH
Oct 31, 2013 | LG 24 in. LDS 5811 Built-in Dishwasher
Hello Do you know where I can download the user guide for the LG LD-4050W dishwasher. Thank you Rosemary
Do a Google search for LG website. There should be a search bar on the website itself and type that model number in and it should bring back your owner's manual.
Apr 18, 2011 | Dishwashers
Lg LD2060SH has no error codes but cannot set program or start wash. when power is switched on Green lights come on then green light only on normal wash. Cannot be moved with control knob and does not...
First check water inflow to the machine. If there is no water machine may not start.
To ascertain further, pour water into the wash chamber manually to the require level and run the machine. If it works check the water inlet.
May 20, 2010 | Dishwashers
HOW TO UNLOCK "CHILD-LOCK"
Press the "Delay Start" and "Program" buttons simultaneously to deactivate/reactivate the child lock.
You may wish to download a free user manual from here.
Please take a moment to rate my answer.
Apr 07, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Hi
Thanks
Rylee
Jul 21, 2009 | LG Dishwashers
Need a users guide
Download the manual from the below mentioned link :-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/HB-152CE-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jul 12, 2009 | Kitchen Appliances - Others
A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
Jan 12, 2009 | Westpoint TV-201 Microwave Oven
User manual
www.thomson.user-manuals.com
Jan 17, 2008 | Audio Players & Recorders
Installing
7e83231.jpgI had the same problem.  Here is the picture I used.
Oct 28, 2006 | Kenwood KSC-WA82RC Car Subwoofer
LG LDF6810 Built-in Dishwasher Logo
260 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
