Question about Logitech Pro 2400 Cordless Mouse
Some keys on Logitech Pro 2400 keyboard do not
The specific keys that don't work on my keyboard are:
2, Q, O, ], F, H, K, ;, Left shift key, on the number pad 7, 8, 9
  • Rich Muth Mar 01, 2009
    The problem was solved by taking the keyboard case apart, wiping down the keypad and CAREFULLY reseating the membrane! ALL keys now work properly!!
    Thanks!!!
  • Logitech Master
  • 13,433 Answers
Has the keyboard got wet? try another usb port?
the buttons or the controller inside may have a problem, new keyboard is quite cheap, if the problem is only limited to this keyboard I would suggest considering a new keyboard.
Posted on Mar 01, 2009
  • Ekse Mar 01, 2009
    You need to take the keyboard apart.
    inspect the keypad below the buttons you have flat flex cable like board that has the keys on it. Inspect it and see if that has a problem, if the keys look ok then the problem is most likely on the controller.
    The controller is the small board the flex is connected to.
  • Ekse Mar 01, 2009
    If certain keys are not touching the flex board below the keys, they wont function as electricity is not passed on from the key.
    taking the keyboard carefully apart and inspecting the boards and rebuilding it may solve the problem incase some buttons are not working properly.
    if that doesn't solve the problem the issue is most likely on the control board or something is cut on the flex cable like board below the keys.
    if you want to fix this keyboard I think you would need to get your hands on a same model keyboard and take parts out of it.
    But this is not really a good repair as a new keyboard doesn't cost much, and the time spend and money in repairing this is not really worth it.
    Test the keyboard on another computer also.
    Thats all,
    Thanks,
    Ekse
  • 19,396 Answers
You need to take apart the casing and replace the keypad.
  • Ginko
    Ginko Mar 01, 2009
    The problem is caused by an hardware fault. Typically one of the wires inside the connection cable that has lost contact with the board inside the keyboard, or a group of keys that has lost contact with the surface below.
    To fix such a problem you would need to take apart the casing and check the contact to the wiring cable, and the contacts below the keys.
    Normally this kind of problems on this device are considered beyond repair.
Where to get spare keys for this?? Logitech refuses to provide them. International shipping back and forth would cost almost as much as this low-durability keyboard did. Often used keys just come off,...
key boards ( usb ones ) are good at $10.00 aud so why worry about it , junk it and get another one
all are warranted for 12 months so if they stop working take it back for ma new one
Nov 24, 2017 | Logitech Illuminated Keyboard
I have a Logitech cordless ex110 keyboard that I would like to find an online manual for....I have no idea what the 'F' keys do and every once in a while I hit something (?) that converts my /,...
Did you install the Logitech Set Point software? If you did, you can edit the Function key assignments by opening that program. There are other ways to change your keyboard settings, pressing Left Alt and Shift can do this with Windows 7 by default. To check this in Windows 7, click Start > Control Panel. Under Clock, Language, and Region select Change Keyboard or other Input method. Once that window opens, click on the Keyboards and Languages tab and click Change Keyboards. Then select the Advanced Key Settings tab. There is a section marked Hot Keys for Input Language.
The manual and other documentation for the Logitech ex110 is available here: http://www.logitech.com/en-us/433/154?selectedcrid=433&selectedcid=154&WT.z_sp=Product&osid=&bit= .
I hope this helps.
May 20, 2011 | Logitech Computers & Internet
Q : I have a logitech keyboard 2.4GHz. Pro 2400 cordless desktop. How do i get it to work? Is there any software to download? I think i have lost something important to get the keyboard to work. Is there...
I'm not sure of the exact model you have but you will have to re-link the mouse and keyboard to the usb receiver. Check your batteries in the mouse and keyboard. If you acquired the key board and mouse from somewhere and you are trying to install it you will need to install software first before linking hardware. this will not work on windows 8 or newer.
Oct 04, 2017 | Logitech Pro 2400 Cordless Mouse
Left shift key doesn't work
If your other shift key works, it could be a possible bad keyboard. You can confirm this with any basic editor like "notepad"
Oct 22, 2010 | Logitech Computers & Internet
Can you tell me what the shift key looks like
Is is normally located on the left side of the keyboard just above the control (Ctrl) key. It may say Shift or it may just have a big "up" arrow.
There is also one on the right side of the keyboard just below the "enter" key and above the Ctrl key.
Jan 19, 2009 | Logitech (967217-0104) (9672170104N)
When hitting the shift keys, the comptuter registers a q or a z?
try cleaning the keyboard
under the keys
sometimes helps
Dec 17, 2008 | Logitech 967437-0403 Keyboard
Split keyboard & capslock shift function
I had a similar problem and noticed I hit the F Lock button. On mine it was a one way plunger stuck down. This caused the problems you mentioned on mine. Prying it up with a paper clip had my unit working immediately. Good luck!
Oct 30, 2007 | Logitech Cordless Desktop MX 3000...
Logitech Pro 2400 Cordless Mouse Logo
209 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
