Question about Goodman GMS90703BXA Heater
Gas furnace stopped; Thermostat to OFF;then ON after 5hrs-worked?
- Cold night for Dallas - in the 20's.
- Inefficient builder-grade, 12-yr old gas furnace was working hard (probably only 10 seer when installed new).
- Only Info I could find on side of the furnace/AC unit in attic:
CAC/BDP
Model: CD3CXA060000
S/N: S2495A00610
Efficiency: 80 AFUE
- Thermostat, Honeywell Chromatherm III, was set to 68 - the usual heat setting.
- At about 2:30AM the furnace cycled on like normal but then turned off very quickly without the normal "click" from the thermostat (Weird how that woke me up)
- Turned the thermostat OFF
- Waited 2hrs
- Turned thermostat ON (heat mode setting we use is "EM HT" so it does not use the heat pump mode).
- Lights on thermostat came on and heard the click like normal, but the furnace did not come on.
- Turned thermostat OFF again.
- Waited another 3hrs.
- Turned thermostat ON to EM HT mode.
- Thermostat again seemed to perform as usual except this time the furnace actually kicked on.
- Any idea what the problem is/was? What are my options? Can/Should I fix it (I have a mechanical mind, but I am not a trained technician) or should I call in a technician?
Thanks for any thoughts, suggestions, advice and/or instructions you can share!
Sincerely,
A cold family of 6 in Dallas
  • colel Mar 05, 2009
    Thank you so much for the detailed instructions and suggestions! I will do as you suggest.
    Sincerely,
    Guru:
  • 462 Answers
You have a carrier or bryant AC Coil model number and the sn says 1995 and its 5 tons and if you actually have a heat pump with the gas furnace you have what we call in the business a dual fule heatpump setup. There are a number of items that could be causing your problem. I would recomend that you first look for the relay box discribed below and if you have that put the wires at your furnace (R &W) together with nothing else on them. If it lites then the problem could be anywhere, thermostat, wiring, the control box which has about 4 to 6 relays. If it dosn't lite the furnace is where your problem is or at least one of your problems is and start there. remove anyother wires on R&W before reapplying power. Also if you have the control box below it will have its own 24v control transformer but your going around that with the test I mentiond here. Oh yes and if it hasnt been modified you'll have to keep the solid door on it to apply power to the furnace.
There are a multitude of items it could be but I believe your age furnace has an auxiliary sensor - relay assembly it is a box about 18 inches long X 6 inches square. has about 10 terminals on it. And it will look like a birds nest with all the wires going and comming out. Id have to suggest you call someone and here's what Id do if I were you. If they say they aren't sure but think its in the relay assembly for the dual fuel control ask them to call carrier or Bryant and request they talk to a service trained expert there or recomend someone. You can do this instead of paying for 2 people. Just ask them if they know about Bryant or Carrier Heatpump dual fuel setup before you tell them to come out.
The newer dual fuel thermostats around $300 - $400 plus an out door sensor about $30 will get you fixed for parts. NO more relay box needed just the out door sensor and the compatable thermostat. if this is where the problem leads. The thermostat cost will depend on if you want the program feature. If someone is home all day Id suggest you probably don't need this feature.
This should get you headed in the right direction. If it helps you please grasde me accordingly, and GOOD LUCK!
Posted on Mar 05, 2009
Home furnace comfortmaker blowing cold air
Home owner's manual? Troubleshooting section. Gas or electric?
If gas, pilot light may be out, or other gas controls. Are you sure you have gas supply? Do you have other Gas appliances so you can check? Furnace needs power for controls, fan and thermostat. Are you sure you have electric power to the furnace? Does the thermostat have a fan switch? If so turn it on and see if the fan turns on. If it does not turn on you may have a circut breaker poped. or some other reason power to the furnace is not working.
Feb 27, 2015 | Heating & Cooling
My gas furnace is blowing cold air. I was told by gas company that it is due to a gas pipe leak. Is this true ? How will it be fixed? What problems can i expect in the future? The furnace is 20yrs old.
If the pilot light is on then it could be in the thermo coupler. If you don't know where to loon it is best to hire a professional. Gas indoors is no joke. Second is that a 20 yr old heater is pretty inefficient and a new one could be had for a little more than the repair costs of the old one and you co upd have another 20 years trouboe free
Feb 28, 2013 | Heating & Cooling
I've got a 23 yr old 30DV3 whose pilot light works, and the thermostat & heating element seem to work, but not well. With the thermostat set at full hot, it just barely throws out any heat at all. ...
As I'm sure you already know, Empire Comforts Systems, no longer makes that model heater and hasn't for some years, now. I mentioned that, because if your unit needs parts, they may be almost impossible to get. In any event, there are a several things that may be causing the problem.
  • Low Gas Pressure - Burner is not receiving enough gas. Check for obstructions and have gas pressure at the unit checked.
  • Clogged burner or air intake (venturi valve) is partially clogged. Clean burner ports and venturi valve.
  • Gas line Shut Off Valve at heater not fully open. Check Gas line Shut Off Valve.
At 23 years old, you've gotten your money's worth out of this unit and it may be time to replace it. Empire makes several Direct Vent Wall Furnaces that are rated as High Efficiency Furnaces. In the long run, the money saved in fuel cost, would be worth installing a new one.
Hope this helps you solve the problem.
Apr 11, 2011 | Empire Direct Vent Wall Furnace;...
30 yr. old honeywell thermostat would not shut off
Try removing the front cover and visually inspecting the metal coil. If there's a lot of dust you will need to blow it off. It could just be that the coil is packed and isn't registering temperature properly.
Mar 23, 2010 | Honeywell Heating & Cooling
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
How to install programmable thermostat
If it is a wall furnace with a built-in thermostat(sounds like the 1 to 10 dial is the thermostat) into the control then you would need to buy an updated gas contol valve that will hook up to an external thermostat and a programmable thermostat. The old gas contol valve would need to be removed and the new one installed. Then the thermostat wires would connect to the gas control valve millivolt system. A heating company can perform this service for you and I highly recommend you have it professionaly installed if you are not experienced on this process. You could leave a gas leak or other hazardous situation if not installed correctly.
Nov 18, 2009 | Vornado TouchStone Vortex Heat 500 Heater
Have a 4 yr old Kenmore model #25374879401 stopped cooling/quiet
you are waisting you money by buying thermostart. you have your gas chockage.... and this can only be resolved by a technician only
Jun 03, 2009 | Refrigerators
Rheem gas furnace pilot lights, but no burners or fan
If the burners do not fully ignite, the sensor will shut the furnace down. The lack of sufficient burner flame is a gas valve or gas pressure problem within the valve.
Replacing the gas valve with the original one may get you going. I surely suggest a professional service company for safety reasons and a thorough inspection. A 20 year old furnace is past it's normal life span.
Jan 06, 2009 | Heating & Cooling
Coleman Propane Furnace Good pilot light but feed/ignite main burner
If you have a volt ohm meter take the two leads off the gas valve and ohm out the connection should have resistance for the coil. You said you have 12 volts from the thermostat white and red in the heating mode you should have minimum 26 volts. If you want to check the transformer should have 28 volts. Almost sounding like the transformer is getting weak. You can get parts for a 20 year old unit at any HVAC parts house. Try Washer Specialties here in Wichita Kansas they are on the web. Lowes even carries Transformers. Has to be rated 120 volt primary side secondary side 24 volts and 40 VAC.
Oct 27, 2008 | Coleman Propane Forced Air Heater...
Goodman GMS90703BXA Heater Logo
290 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
