Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Replace wire clamp around seal
We had to remove the rubber seal on our LG WM0624HW, as it was clogged and filled with sludge which was getting on our clothes. Now we can get the clamp that hold the rubber seal back on the washer.
    Scholar:
  • 106 Answers
You need a grip clip plier to handle this clip, enquire at a hardware tool shop, with problem. The clamp is tough, you dont want leaks.
Posted on Mar 01, 2009
LG HE Waher model WM2010c, rubber door seal slid and distorted the seal edge, on a spin cycle with a towel in it, how do I fix this?
If seal/boot is not torn, then remove front spring/wire clamp, reposition the seal/boot, reinstall the spring/wire clamp. Check out repair videos at appliancepartspros.com or repairclinic.com.
Feb 01, 2017 | LG Washing Machines
Need to remove the rubber seal from my lg front load wahser
why replace seal just clean it much easier there are some really good cleaners on the market but if you realy want to replace remove wire band around seal you will see this around the outer diameter with a tension spring attached pry of carefully lift the top and do the same at other end make sure to turn of power take very good note so you will know how to put back together
Nov 12, 2009 | Washing Machines
A HOLE IN THE RUBBER SEAL
You can certainly diy. Unplug the washer. With the door open, look at the bottom of the seal. You'll see a ring clamp. Loosen the screw and remove the clamp. Peel the seal inward. It is easier to complete the seal swap with the front off. Remove the door and set aside. Locate the screws for the front of the machine and remove them, gaining access to the seal. Youcan either set the door to the side with the door lock wires still attached, or unclip them, which is easier. With the seal folded inward, you will likely find another clamp at the bottom. Loosen this as well. Remove the seal and replace with the new one, making sure to orient it like the old one was, and fold it to the inside like you had the old one for removal. Replace the front panel. Complete the seal installation, being careful to make sure that the clamp removed earlier gets put back in the groove and seats well. Reinstall the door. Best Regards, --WoobieDog--
Jul 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Rubber door seal replacement on my Front Load Washer
OPEN THE DOOR
THERE IS A WIRE AND SPRING CLAMP AROUND THE SEAL, PULL BACK THE SEAL WITH YOUR FINGERS AND YOU WILL SEE IT
TAKE OFF THE CLAMP
FOLD THE SEAL BACK INTO THE DRUM
YOU WILL SEE ( OR FEEL ) A CLAMP AROUND THE SEAL ON THE DRUM
SLACKEN OFF THE SCREW HOLDING IT UNTIL YOU CAN PULL OFF THE SEAL.
FIT A NEW ONE IN REVERSE ORDER.
HINT- WIPING WITH LIQUID DETERGENT WILL MAKE IT EASIER TO FIT THE NEW SEAL.
HINT2 - YOU MAY NEED 4 PAIR OF HANDS TO FIT THE SPRING CLAMP
Jul 06, 2009 | Whirlpool Washing Machines
Put wire clamp back on rubber seal
You need a special pair of pliers "grip clip". Explain what you want it for at a hardware store. Saves you much sweat.
Mar 01, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG FRont Load Washer Dryer WD-1256RD filling up with lint
If you have not done it already, replace the lint filter. Follow instructions on manual. The lint filter access should be on front side of machine.
Other users had same problem on this model, I quote:
"I've only had it 2 weeks so far. It seems to be collecting lint/fluff all around the rubber door lining"
Source here.
Sometimes there may be too much lint if you use excessive softener and detergent.
Feb 08, 2009 | LG WD-12124RD Front Load Washer
I do not know how to install the new seal I ordered for my front loader it is a large rubber circular piece. help
There are two large spring clips that hold the seal in place.
If you open the door and feel around the outer edge of the seal you will feel a metal wire that is held together by a short spring. You need to expand this spring to enlarge the wire circle (not too much as you can cause damage to the spring itself). Most techs use 2 vice grip needle nose pliers to do this. Once the spring clip is off you will need to fold the seal inward. Around the base of the seal where it meets the tub there is another wire spring clip assembly. You will need to remove this one as well. If there is a drain port on the seal you will need to un-clamp this one as well
The new seal goes on just like the old one came off. you will need to expand the spring to clamp the base of the seal around the tub. and again with the uoter seal lip around the opening of the door panel.
This procedure can be quite tricky and LG does have a special set of pliers for this job. It can be done without the special tool but it require quite a bit of patience and strength.
Aug 05, 2008 | LG Washing Machines
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
The rubber seal kenmore 3.8 cu ft he3t king size capacity
Here ya go. These are the complete steps involved i how to replace the door bellow. Just follow these instructions:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the screw(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you and let me know if you need further assistance.
Apr 12, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Whirlpool duet washer seal leaking
It is recommended that you replace the rubber seal rather than try to repair it. It is not a difficult repair and the rubber seal generally runs about $80. Most appliance repair places will charge more for the part, plus a labor charge. The result could be a repair bill of over $200. If you would like to attempt the repair yourself, here's how:
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will dettach from the tub.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. Sometimes the tube is not inserted all way into the boot and water will leak behind it. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Then, beginning at the top start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be adviseable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful. Let me know if you have any further/questions and concerns. Good Luck to you.
Nov 30, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
138 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
