Question about Singer Sewing Machines
Bobbin/thread tangles As I sew, say for the 'distance' of hemming one pant leg, the thread underneath tangles into a big mess of thread. I have had this problem a few times over three years and each time I took it in for servicing. It was 'fixed' each time. I took it into three different places and the last place, recommended by a friend, explained that the machine, being that it is a more than 40 years old, a Singer, needs both oiling and lubrcating every so often depending on how much you sew or how often you use it. I checked the manual last night on how to oil it and it looked like a diagram out of connect-the-dots -- too much work for me -- taking the bottom plate off, the top plate and so on, to oil at least 30 spots, and it didn't even mention lubricating it. I was checking into a Euro Pro (model 464XC) on eBay and found it has the same problems. My machine is good, but it needs to be in a home with someone who loves the Singer and has more time and patience than I. What machine would you recommend for someone with simple sewing needs? And I don't want to have the tangled bobbin mess any more. I wouldn't mind purchasing new -- warranty and manual, but would consider used at a really good low price down the road if need be.. Do you think it's worth it for me to try and sell mine? Thanks for your help, WH
    Scholar:
  • 69 Answers
All sewing machines will require maintenance. The difference being that some machines (most made these days) require servicing from a technician. The older machines have the instructions and the owner is able to do the oiling/cleaning themselves. If you don't mind paying for the service then how often depends on use. If you use your machine regularly, say at least once or twice a month, then you will find you would need service about once yearly. If you never use your machine, say once or twice a year, you may find it needs servicing every time you try to use it.
If you wish to purchase a new machine, what machine depends on your amount of usage, types of sewing and such. There are a lot of good easy to use machines on the market, my suggestion is to stay away from the Discount house machines. These may look ok, but they are much cheaper parts inside. My suggestion is to go to a local sewing shop and sit down and sew on the machines. When I sold them I always told people to bring in a sample of the type of sewing they do. If the salesperson won't let you sew on it, don't buy from them. If you want to email me with the types of sewing you do and such, I'll see if I can help you find one. csews@email.com
Posted on Mar 01, 2009
There is something wrong with the bobbin. When I sew it catches somewhere and bunches thread up underneath
Does this only happen when you begin sewing????? Make sure your upper and lower threads are long enough for you to hold them.......lower your pressure foot and don't release the threads until you have sewn several stitches into the seam. If you don't hold the threads when starting a seam...both threads often get pulled down into the bobbin area and cause a big tangled mess. Hope this helps.
Dec 20, 2010 | Kenmore 756A-30BH Mechanical Sewing...
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled....
My Husqvarna started having problems with the bobbin. The thread from the bobbin side is a tangled mess when I stitch. The top looks fine, but the seam falls apart easily and the backside is all tangled. I cleaned underneath the bobbin holder but it didn't help.
Oct 13, 2010 | Husqvarna Viking 1
I have a Necchi 535 sewing machine and the thread tangles
if the thread under the fabric is a matted mess
1.the needle thread tension is to loose
2.needle is either to heavy or to fine for the thread
3.check to make sure the thread isn't off the thread take-up lever
Jul 30, 2010 | Necchi Sewing Machines
Thread is tangling on the lower bobbin
check the needle first.Bent or spurred needles will result in this action.
May 30, 2010 | Brother XL-3510 Mechanical Sewing Machine
The bobbin is loaded but when i go to use it I get a tangled mess of thread underneath my fabric
Usual cause is bobbin threaded wrong or more commonly improper tension of the upper thread. Sometimes the bobbin tension may be wrong due to thread size change etc.
Sep 04, 2009 | PfaFF Sewing Machines
Lower thread problem
are you still looking for an answer? if so I can help but I don't want to type all day if you already fixed it.
Sep 14, 2008 | Brother XL-6562 Mechanical Sewing Machine
Cant hem unable to workout what length to start with to end up with the correct length required looking at the manual it says to take the hem and fold it over etc. but its very confusing
Sorry, I don't understand just what you mean by "length to start". Length of what - stitch? hem turn-up?
Let us assume you are taking up a hem of a pair of pants. Try them on and put a pin where you want the hem to finish i.e. this will be the bottom of the pants. Take pants off, turn them inside out (careful that your pin does not fall out!) and fold the excess pants on that pin mark. The excess fabric should be on the outside, not tucked inside the leg tunnel. Measure how much it is from the existing hem to where you folded it over, let us say for the purposes of this exercise it is 4 inches. Your hem is to be 1 inch and you need 1/2 inch to turn under for a neat finish, total 1 1/2 inches, so you need to cut off 2 1/2 inches from the bottom of each pants leg. Fold 1/2inch at new leg bottom (wrong side of fabric to wrong side), press, fold 1 inch hem same way and press. Place pins every 2inches or so at a right angle to the hem edge. Pins should come out 1/4inch from edge of hem where the 1/2inch neatening fold was made (this is where I wish I could draw a picture!). Fold the hem back inside the leg tunnel. The pins should make the fabric fold under only enough so that 1/4inch of the hem sticks out beyond the pants leg. You will sew on this bit using the blind hem stitch (04 on my 7550). You might need to adjust the stitch width - not length - so that the straight part of the stitch goes along the hem bit and the zig-zag JUST bites into the pants leg fabric.
I do hope this lengthy explanation is of some use to you!
Jul 01, 2008 | PfaFF Creative 7570
The bobbin string gets tangled in a big mess and jams the machine
adjust the thread tightness. thread tension might be loose enough. be sure also the the bobbin inside the machine is place correctly! reversed placement would result in bigger mess.
Feb 26, 2008 | Brother XR-65t Mechanical Sewing Machine
Sewing Machines Logo
258 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
