Question about Epson Stylus Photo RX500 Printer
IS THERE ABILITY TO PRINT BLACK INK ONLY WHEN OUT OF COLOR INK?
EPSONSTYLUS PHOTO RX500
  • 3 Answers
First go to your start menu. Then click on Printer and Faxes. When there right click on your printer and select Properties. When this window opens go to the General tab; then go to the Color tab. There you will see a box that you can check for printing in Gray Scale Only. Check this. After you have checked it, you can then check Black only.
If you wish for this to remain that way until you replace the other colors, be sure to click on APPLY or it will only print the first thing that way. After you have replaced the ink cartridges, use the same tabs to cancel the gray scale selection!
Posted on Mar 01, 2009
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
I just want to print with the black ink, even though some of the colors are out of ink, so now my printer is giving me an error message and I cannot use the printer at all. How do I override this NOW...
Unfortunately you can't print anything unless you replace all the empty ink cartridges. There is no way to override it. Epson printers work that way, sadly!
Feb 10, 2010 | Epson Stylus Photo RX500 Printer
Epsonstylus CX7800- when printing color
well you must use the correct ink, you use a very thin ink, that´s way it´s bleeds, the ink is very metal corrosive, and destoy al mec. parts and bunsout the print head. NOTE:you have ruined your printer, the repair is very expensive.
Jan 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I just re inked my Epson styles Photo RX500. All the ink levels read low except Black. I removed all the cartridges and repeated the process.and, all the ink levels read low except black.I get a ERROR...
what is the error message? try to turn off and on your rx500. note for an epson printer it requires all inks inorder for it to function or else it will be on an off line state
Sep 14, 2009 | Epson Stylus Photo RX500 Printer
Ink inserts show adequate ink but printed copies not proper color
Try this: Using the Guide for the software (don't you have an icon for the guide on your desktop?) select the "printing" troubleshooting option. It should show the steps to cleaning the print heads and how to do a nozzle check. It is really easy to do both, just click where it reads "clean print heads" and "nozzle check." I'm not positive this is the solution to your problem but it is worth a try--better than trying to get anything out of Epson's tech support. (Good luck with that!) I hope this does help.
Mar 17, 2009 | Epson Stylus Photo RX500 Printer
I have an epson stylus PHOTO RX500. I need to change the "black" ink cartridge but the ink carriage will not move into a position that will allow the top of the ink carriage to be lifted. When I push the...
Try unplugging the unit and then plugging it back in. When you first power it up, it should do an initial system check, which involves moving the print head. Unplug the unit the moment the print head is in a position to change the cartridge. I did this with my old Canon when I had the same problem and it worked. Hope it works for you too.
Feb 08, 2009 | Epson Stylus CX5400 All-In-One InkJet...
The RX500 prints only one color or two
See my previous posts about intensive cleaning and you should be good to go again: http://www.fixya.com/support/t138226-printer_not_printing
Jun 28, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson stylus photo RX500
Turn the printer off overnight and try the head cleaning process again. Leaving it unpowered for an extended period softens the ink and makes the cleaning more effective. It may require several cleaning cycles.
Apr 05, 2008 | Epson Stylus RX500 All-In-One InkJet...
RX500 EPSOM STYLUS PHOTO PRINTER Won't Print
I used some less expensive generic ink cartridges on my RX500 and had a similar experience with the black. If you're already using the Epson brand, done the head cleaning, realignment and nozzel checks, I'm not much help. Try Epson's support at their web site.
Mar 25, 2007 | Epson Stylus Photo RX500 Printer
Epson Stylus Photo RX500 Printer Logo
259 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
