Question about HP (Q6473A) Print Cartridge for Color LaserJet 3600 Series. Magenta Printer
My 3600dn indicated need new cyan cartridge. I installed new one
But it responds as if I did not replace. I purchased another cyan cartridge today and got the same response. I have installed approximately 6 cyan cartridges in the past. We just installed a new black cartridge. What can the problem be?
    Genius:
  • 2,120 Answers
A bad refilled toner cartridge.
Posted on Mar 02, 2009
  • Leroy Elliott
    Leroy Elliott Mar 02, 2009
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
Not printing black on right side of doucements
Run the PQ Troubleshooting diagnostic
Check out the BLACK page.
You can also run the Disable Cartridge Check diag.
This test will enable you to pull all the cartridges out, and put the black into any other slot. Then print the Configuration Page and see if the problem follows the black cartridge. If it prints good this way. Put the Cyan into the top slot(black), print the config page. If it prints bad, it's not the cartridge it's the printer.
I think that replacing the Black Cartridge should solve your problem.
Jan 05, 2011 | HP LaserJet 3600dn Printer
The printer will not print after I installed a new 02 Cyan cartridge. The printer display still indicate that I cannot print until I replace the cartridge
You don't state what type of printer, but many require entering the maintenance menu section to indicate the cartridge is changed. Consult the printer's manual (you didn't throw it out, now did you??)
Jun 14, 2010 | Computers & Internet
My 3600 dn is printing tiny small cyan dots on the paper...always in the same spot about 1-1/2" from the edge. What would cause this? A spec of something (i.e. dirt) on a roller? Or? I would like to clean...
The dot could be from the cyan toner cartridge. There could be a mark or scratch on the image drum surface underneath the cartridge shutter. If it is a toner mark it can be carfully cleaned with a lens cloth. If scratched or nicked the cartridge will have to be replaced.
Jun 09, 2010 | HP LaserJet 3600dn Printer
It might a problem of mismatch cartridge. The printer is not detecting the cartridge as is it not getting the exact type of the cartridge, check the exact cartridge number and type and install it.
Jun 01, 2010 | Computers & Internet
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Install Cyan Toner Error
ensure that the one you install is the exact model name and number, if this is correct, try unistallling once again and check one more time,
you might want to get a new cyan toner if this still fails, i dont think there is a prob in your machine, cheers
Aug 16, 2008 | Samsung CLP-510 Laser Printer
Tank indicator did not show cyan tank low/empty, after changing tank, still no blue color
1) Make sure the tape was removed from the cartridge when installing the new one.
2) Try running a few cleaning cycles as this primes the cartridge.
3) DO not print without ink as it may damagew the head.
Jan 17, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Error Codes
Hi , The 59.61 is a problem with the Cyan print cartridge drive motor and occurs during startup or rotation. The first thing you will have to do is replace the cyan drive motor and if that doesn't correct the problem then the dc controller. But I'm pretty sure the motor has failed for the cyan. Now I'm not talking about replacing the Cyan Toner Cartridge!!!!
Dec 04, 2007 | HP LaserJet 3600dn Printer
HP (Q6473A) Print Cartridge for Color LaserJet 3600 Series. Magenta Printer Logo
199 people viewed this question
Ben Johnson
