Question about SanDisk Sansa MP3 Player
Micro sd probelem
I've gotten a 4gb micro Sd card to boost the memory of my Sansa Express. i've never been able to use the mp3 player before. every time i turn my sansa express on, a screen goes on, saying : Refresh Database do Not Remove SD. and then i wait forever hoping to listen to my songs, then the battery goes flat -.-
HELP ME
  • Anonymous Mar 20, 2009
    I called their 800 number before I bought the player and they told me it could use up to 4 G cards. Of course they do not work and I can't return them.
  • Anonymous Apr 02, 2009
    I have the same problem with a 2 gig micro card....any ideas?
I use a 4gb Sandisk MicroSD Card in a 1gb player and it works. No long delays at switch-on either
Posted on May 15, 2009
  • 728 Answers
Well, the most memory from a micro sd card the Sansa mp3 player can take is 2gb, because anything more will freeze up the player because it was not designed to read that much memory. So if you have a 1gb or a 2gb memory card, then you can use them.
Posted on Mar 02, 2009
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
Mar 10, 2013 | SanDisk Sansa e250 MP3 Player
Installing Micro SD card to Sansa e260R
The Sansa e260 Rhapsody (e200R series) supports:
1. micro SD cards ( not the HC type )
2. micro SD cards up to 2 GB of memory capacity
See next site:
http://kb.sandisk.com/app/answers/detail/a_id/200/related/1
Jan 10, 2010 | SanDisk 4GB microSD High Capacity Memory...
Sd card problems
try downgrading the sd card make it a 2 gb card
May 29, 2009 | SanDisk Sansa e200 MP3 Player
How to sink micro sd card with player
You should probably just copy the mp3 files directly from their source folder over to the micro sd. To do this, put the micro sd into some type of adapter that will allow the computer to read/write to it. There are usb sticks that do this and there are SD adapters you put the micro into so you can use a media reader/writer with it. Once you have the card seen by the computer, just drag and drop your MP3's into the drive letter corresponding to the memory card. After that is done, put it back into the player and turn it on. I should find all your songs and make them available to you.
Mar 13, 2009 | SanDisk Sansa e260 MP3 Player
I need to know the maximum GB external micro sd card I can put in a sansa E260 4 GB Mp3 player and a sansa express 1gb mp3 Player.
thank you for choosing Fixya.com
you can use 4GB it is the applicable memory on your mp3.
if you will try to use much higher than 4gb sometimes it is the reason why our player are hanging up.
please don't forget to rate our answers properly.
Mar 05, 2009 | SanDisk Sansa e260 MP3 Player
Trouble with expanded memory
The Sansa Express was only designed to hold up to a 2 GB Micro SD card because that is as much expandable memory it was meant to read. Anything bigger as in your case will cause the player to go slower than normal as it tries to read the card and after a while, it will most likely freeze. If you try it with a 2 GB Micro SD card, it should work.
Dec 10, 2008 | SanDisk Sansa MP3 Player
My Sansa Express Music Player shows mulfactioned error
Insert A Micro SD Card And Start It Up
It Should Work
Shut It Down And Remove The Micro SD Card
It Should Startup Fine.
Sep 09, 2008 | SanDisk Sansa c150 MP3 Player
Micro sd 4gb card problems.
Check the Sansa tutorials at http://www.sandisk.com/Retail/Default.aspx?CatID=1468
to make sure you have followed all the steps first.
In my experience, every mp3 player/photo frame/etc with a card reader has a MAXIMUM memory limit for the type of card that it can read. It is possible that the Sansa player can only read 2GB Micro SD cards or smaller - and thisi nformation may not have been available when they printed the manual. If you have followed all instructions, and it still will not read the card, try switching to a 2GB Micro SD card.
Mar 22, 2008 | SanDisk Sansa e250 MP3 Player
Memory stick not identified.
The memory stick probably is not the right type. The Sansa only takes SD Micro chips. However, IIRC Micro only goes up to 2GB. So, if you have a 4GB chip is must be a SD HC (High Capacity). Unfortunately, these do not work in the Sansa.
Feb 28, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
Nov 13, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
337 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
