Question about Dryers
No fire maytag dg512 serial 723019 dryer stopped heating yesterday. drum turns,everything else works except it does not heat. anyway i can fix it without the expensive call ,the dryer is about 20 yrs. old
  • 360 Answers
This link --->click here<--- is the exploded view for your unit. If you look at diagram 4 (gas valve), the first guess would be a faulty igniter (diagram location 12). This is only a guess for no tests have been done to narrow down the faulty component.
If you need assistance, let me know.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Mar 01, 2009
Maytag dryer stops running after 10-15 seconds.
Check the exhaust vent in the dryer and the one going outside, sounds like it's plugged. If it's plugged the dryer will get hot real quick and shut off so it doesn't catch fire...
Dec 11, 2014 | Maytag Dryers
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
Maytag dryer drum not rotating
Sounds like the belt that turns the drum has slipped off or broken. Not sure if I would consider this a DIY project, but if this is the problem, a professional fix should not cost much.
Jun 19, 2012 | Maytag Dryers
Gas Dryer only runs burner once after starting, why
Lets see, you have power to the gas assembly so the fuse is good and the ignitor will fire up. But she won't fire off again. The flame sensor is working because the ignitor is coming on and off. That means the control thermostat is working so everything is working. So what's the problem. Simple.933a1bb.jpg The solenoid coils heat up and quit on these machines with a little age. Very difficult to diagnose unless you know the trick.
Cheap parts link, your part sir: AP3094251,
May 14, 2010 | Maytag MDG2706A Gas Dryer
I have a Roper Gas Dryer model RGX5634KQ2. The
My bet is that your ignitor is bad....change the ignitor and you will be working again...
Here is a tip that I wrote about your problem that will explain it further...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
heatman101
Mar 30, 2010 | Roper Dryers
Power on but it won't spin.
You have a broken drive belt. To access the belt you have to remove the back metal cover.
The no heat problem could be a heating element or safety thermostat. These are also located under the back metal cover.
Jun 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dryer drum wont turn
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Dec 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
