Question about Saws
Ryobi Scroll Saw runs at maximum speed
I have a Ryobi Scroll Saw that has been used very littlie. It is a few years old but has only been used 2 or 3 times. When I turn it on the saw runs at maximum speed for about a second and then stops no mater where the speed control knob is set. Does anyone have any trouble shooing data for the electronic speed control ?
  • 154 Answers
Unfortunatly the speed controls cannot be repaired, they can only be replaced. You will have to find a Ryobi dealer in your area and get a new speed controler.
Posted on Apr 15, 2009
I want to make my ryobi sc 160 single speed scroll saw to a varable speed saw I took it apart and there are no brushes
if you do that you will only burn your single speed saw up . they are not made to run on low voltage .
Nov 24, 2015 | Ryobi Saws
Ryobi 725r carb adjustments
Zama Carb? Turn both low and high meter screws 2 full turns counterclockwise, and idle speed control to maximum. Prime unit and start motor. Run for about ten seconds and then turn idle jet (clockwise) for maximum rpm and then lower idle rpms - readjust idle meter as necessary along with idle screw. Then gun unit at high speed and turn high screw for maximum rpm. Go from idle to max and make sure there is a smooth transition. If not play a tad with the idle mixture screw till that is achieved.
Oct 22, 2015 | Ryobi Garden
Need initial carbueter settings for jonsered 2041 chainsaw
Basic setting H 1 turn out L 1 1/4 turns out, you will have to fine tune from there, maximum free no load speed 12500rpm idle speed 3000 rpm
Apr 19, 2013 | Ryobi Factory Reconditioned 18" 40cc...
How to adjust fuel air mix in Ryobi Lawn hornet
hello sir,, now there are two types of carb.adjustment screw covers,the old one where there are plastic over the screws,simple remove the plastic covers with a pair of needle nose pliers or cutting off,,,second are the new ones that are above the adjustment screws,which you have to take your drummel tool with the cutting blade and cut slots in the screws, after you get this done it is important to count the number of rotations in until stops make note how many. because you are going to reset the same way.now remove the screws,put to the side when you get ready to put screws in put in all the way than back out as many turns that you noted, now that is factory set there should only be a small adjustment to do. the rule of thumb is turn both out 1 1/4 turn and adjust in until saw runs smooth and idles ok, it is hard to adjust the top speed when saw is running wide open,let saw idle when adjusting top speed is easier that way, when you go to cut wood you may have to readjust top speed, the above does apply some what if you are not using fresh gas mix and dumped out the old fuel and starting with fresh,and a new plug CJ8Y,and as you know the saw has to breath in and out by this i mean a clean air filter,make sure the small screen on the muffler is not cloged,this will keep saw from running at peak speed and sawing wood, ok i have ran across a few saws to where the small screen in the muffler is cloged so the saw would idle but not run at high rpm's,if you do and check all of the above your saw should run,oh btw check compression should be above 60 to 160 lbs, hope this helps,any comments welcome,please accept my solution,thank you. 00
Feb 12, 2012 | Ryobi Garden
What is the gas to oil ratio for the Ryobi 10532 18 inch chain saw?
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Oct 18, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Idle is off??
hi leobowdy
disassembly the carb and carefully clean it.Check the air filter,the fuel line and fuel filter,check the needle,lever,small spring and the screen filter from the carb.Check the sparkplug.
high speed H=2 turns,low speed L=2 1/2 turns,adjust T
When chain saw starts adjust H,L and T accordingly.
cheers savumihai71.
Nov 22, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Saws Logo
380 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
