Question about Akai PT4799HD Rear Projection Television
Akai PT4799HD - Bluish and Distorted Screen
I have an Akai PT4799HD Rear Projection Television, I was away from home for a few months, when I came back I turn on the TV and it displayed a Bluish and Distorted Screen. Mostly blue shadows. You can distinguish some of the menus (text), but they are also distorted. However, I never felt a burning smell. I also can hear sounds. I would appreciate if someone can guide me to solve this issue.
Thanks ahead for your help...
  • Akai Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from
www.TvRepairKits.com
Posted on May 15, 2010
Where can i get a replacement screen protector for my akai tv 47 inch rear projection
Not replace able,beacuse the DLP screen cost the same as a new not including labors.Tv not worth it to just replaced the screen.
Jan 12, 2010 | Akai PT4799HD Rear Projection Television
Color distortion in an Akai ( Cheaper model Rear Projection tv) I
Ur convergence is dead.Try Tv repair World.com.
Buy a whole convergence board replaced it.
Jan 01, 2010 | Akai PT4799HD Rear Projection Television
Where can i get a convergence chip for PT4799HD akai tv?
I'm fairly certain that particular Akai model contains Samsung parts. You can contact Samsung at 1-800-726-7864 to check pricing and availability of the part you seek.
Jul 12, 2009 | Akai PT4799HD Rear Projection Television
I was watching TV this morning, and I heard a slight pop from the back of the TV the picture then became distorted, blury, and off color. There is also a "burnt" smell coming from the rear of the tv, I...
One of your capacitors n the video board burnt out. You will have to use a multi-tester or capacitor tester with service manual to determine which capacitor it was that burnt out.
Jul 06, 2009 | Akai PT4799HD Rear Projection Television
Pt4799hd akai projection tv is all orange
check the brightness control on the three colors controls, they could be off.
May 05, 2009 | Akai PT4799HD Rear Projection Television
Double Letters-One in Green other Red in bottom corner
yes goto menue and goto convergence
line up all red blue and green cross hairs so thay are wite.
thanks.
daniel
Jan 13, 2009 | Akai PT4799HD Rear Projection Television
DISTORTED PICTURE
Problems with voltage regulation is the usual case for what you are describing.
Jerry G.
Apr 29, 2008 | Akai PT4799HD Rear Projection Television
AKAI FIX
My set had the same issue with the picture and burning smell. On my set, I just removed the cap and the set works great without it.
Aug 08, 2007 | Akai PT4799HD Rear Projection Television
Burning smell and distorted picture
One of the components in the horizonatl deflection circuit went bad like a capacitor,the price will depend on the actual part that went bad and your location,the service call in NY could be 300.00 but in pittsburgh might only be 150.00.I still belive is wort repairing.
Oct 18, 2006 | Akai PT4799HD Rear Projection Television
Akai PT4799HD Rear Projection Television Logo
175 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
