Question about GE Dryers
Replacing GE motor 5KH47DT61T with WE17x32 wiring issue
GE dryer DDG7280PALHT replacing GE motor 5KH47DT61T with WE17x32 cant get wiring on centrifugal switch correct. The new motor wont run.
TheMobilian
  • 8220 Answers
SOURCE: GE dryer DDE5300 runs only
Broken belt. The safety switch will not allow the motor to stay running if the belt is broken. Open the door and look up at the 12 oclock position and their will either be 2 or 4 screws holding down the top. These must be removed and then you can get the top to come up(or off on newer models). Once you have the top up you can get to the screws which hold the front on (2). Then you simply remove the front and get it out of your way. On some these dryers there is a friendly rear hatch to help you replace the idler.
Posted on Jan 09, 2009
dragonsthatk
  • 547 Answers
SOURCE: need schematic for replacement motor GE dryer model DDE6350GALWH
http://www.partstap.com/ please go here for diagram thank you please rate me
Posted on Feb 22, 2009
protek480
  • 1714 Answers
SOURCE: I cant find the right conections diagram for the
The dryer has a diagram on the machine. The centrifugal switch is on the end of the motor and they close when the motor is running. This contact is in the element circuit.
Posted on Jul 11, 2009
SOURCE: Dryer blower motor runs slow and makes loud humming noise.
It will almost certainly be the capacitor. Instead of buying the $60 part thru parts suppliers, I went to a local engine repair shop and bought one for $8.50 and installed it. It worked fine.
You can order the part from Beidlers motor repair, just as I did. Their number is (304) 263-9995
Posted on Dec 05, 2009
  • 2526 Answers
SOURCE: The centrifugal switch on the dryer motor is broken
kenmore dryer motors are very easy to change out,
Posted on Jul 17, 2010
I have a GE Electric Dryer model DPVH880EJMV. It stopped working and displays error code E12 - "Motor is not rotating or centrifugal switch is bad". Anyone run into this issue before or have a fix?
Jeff,
If your centrifugal switch is bad, more than likely you are going to need a new motor because those are built into the motor. The only other thing to check is to find out if you are actually getting power down to the motor. If you are, then motor problem, if not, then something else is bad that is not letting the current get to the motor. If you can find your wiring diagram, you should be able to find which wires deliver the current to the motor and you can back track to see where you lose the current. Hope this helps!
Jun 05, 2015 | GE Dryers
Why doesn't the dryer stay running when I let go of the start switch?
Hi, There is only one reason I can see the dryer stops after you let off on the start switch is the motor because GE motors has start switches either built inside the motor which is non removable or built outside the motor which can be replaced .
Its called a motor start switch and the way to locate it is to remove the front panel on the dryer and remove the drum and belt and then write down the motor model number and look at all the wires that go into the motor which is your motor start switch that is held in by two screws but before you remove it don't forget to copy the wire down on piece of paper of how you remove them .
If you don't see a black switch to the motor then its built in and the motor needs to be replaced.
Oct 23, 2014 | GE DWSR483EBWW Electric Dryer
Replacing ge dryer motor need wiring diagram
Need model number to provide wiring diagram
Dec 19, 2013 | GE Dryers
Manual for ge dryer m460-g
_ _ _ _ 4 6 0
can you fill in the blanks?
Feb 22, 2012 | GE Dryer Motor WE17X32 WE17X10010
My beaumark dryer model # 640504191 has a motor issue
Sounds like a tension device came loose alowing motor to move into bad spot and cant run now
Aug 23, 2009 | GE Dryers
Dryer vibrates with exhaust hose attached
Doubt this has anything to do with the drum replacement. Your model has an independent variable speed blower motor (not linked to the motor which turns the drum) and speeds up when it senses a vent restriction. You may have a problem with the vent motor or blower wheel, or just a vent restriction issue.
May 21, 2009 | GE Profile Harmony DPGT750EC Electric...
Blower motor access
You cant you have to remove the control panel, dryer top, top heat shield, dryer front, front drum support, belt, and then the drum in that order to get to the heater. I have been working on these since they have been out and have never changed a heater in one, They just dont burn out. Unplug the dryer and take the access cover off where the power cord attaches to the dryer and make sure the wires are not loose or burnt.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryer intermitantly drys.
I have replaced several blower motors on these units for that problem. If the board doesn't read the blower motor speed it won't turn the heater on.
May 15, 2008 | GE Profile Harmony DPGT750EC Electric...
Motor centrifugal switch bad
You cant get the switch seperate for that motor, you have to get a whole new motor.
Oct 31, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
277 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
