Question about Canon PIXMA MP160 All-In-One InkJet Printer
Error message: Service error 5100 on my new Canon MP160 Printer
I have a brand new Canon PIXMA and i have downloaded all of the software as it told me to in the directions that came with the pc.... but when i got to print something i get an error message that pops up and says service error 5100. can anyone help me with this? Please help i have MP160, i bought new inks but when i already put the new cartridge there was an error saying "the holder is in the replacement position, After replacing the ink cartridge, close the printers cover " i close the cover but when i tried it agian this message appeared. "the printer cover is open. if printing is in progress, the cartridge cannot be changed. Close the cover, wait for printing to finish, then open the cover again and change the print head or ink tank" But it was close.. Really do not know what;s wrong
  • 412 Answers
No prob try -- As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
Error occured/error 5100
just reset your printer eeprop by software.type generaltool for canon mp160 and googlee it.run software,connect your printer and reset your printer eeprom.
Jun 17, 2012 | Canon PIXMA MP160 All-In-One Printer
Pixma MP160 has service error 5100
5100 says the carriage is not free to move all the way left and right, or there is ink or grease on the encoder strip, the plastic strip behind the carriage assembly. You can clean the strip with a Q-tip just damp with water.
Sep 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Service error 5100
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-7
Aug 05, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Says service error 5100 on my canon mp160 printer. it said cancel printing, turn off then back on. didnt work. what do i do?
5100 is a carriage error, make sure there is no paper stopping the carriage from moving right to left, and then clean the encoder strip, behind the carriage, carefully with a damp Q-tip. Usually grease gets on the strip and gives you that error.
Jul 27, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My canon pixma mp 160 not working.apear 5100 error
hi,
ppobmi17
Jun 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My MP160 Printer is plagued with problem Service Error 5010. Neither I can print nor scan. Please help me to fix the problem.
hi,
ppobmi20
Jun 20, 2009 | Canon PIXMA MP160 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon MP 160
hi,
prirweto-i-2
Feb 14, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
269 people viewed this question
old marine
old marine
