Question about Lexmark X5650 All-in-One InkJet Printer
Cannot receive fax on Lexmark x5650. I can send out to their rest number, but the return incoming fax says not connected. I've installed and reinstalled at least 20 times. lexmark support spend time also;finally able to fax out just cannot receive. Am faxing direct from the machine which is hooked up to the printer and phone line.
Rebgagnon
  • 382 Answers
SOURCE: CANCELLING AN INCOMING FAX JOB
SHould be able to power down unit and remove power cord for few minutes. That should erase the Stored memory that it has been set into.
Posted on Jan 29, 2009
ginko
  • 19396 Answers
SOURCE: i lost the Lexmark X5650 Printer, Scanner, Copier
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Mar 05, 2009
atienzajude
  • 58 Answers
SOURCE: Lexmark X5650 cant scan
TRY TO REINSTALL THE SOFTWARE AND A DRIVER FOR THAT MODEL DRIVER
Posted on Aug 06, 2009
SOURCE: i havw a lexmark x5650, how do i get the fax to
my printer lexmark x5650 says the carrier is jammed how do i fix it
Posted on Apr 19, 2010
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: how do I change baud rate on Lexmark X5650 in
    Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
    Posted on May 06, 2010
    MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
    Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
    If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
    If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
    Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
    I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
    Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
    Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
    My Lexmark X5650 (Model number: 4437-001) will not auto answer faxes. It can be manually be answered, and the settings are for auto answer. I can also send faxes too with no hassle at all.
    bbargains,
    Here is the correct procedure to receive a fax automatically;
    Make sure the printer is on and is connected to a working phone line.
    Make sure that Auto Answer is on.
    To check if Auto Answer is on:
    From the printer control panel press the wrench sign.
    Press the arrow buttons until Fax Setup appears, .
    Press the arrow buttons until Ringing and Answering appears, and then press
    OK to save the setting.
    Press OK again.
    Check to see if Auto Answer is set to On.
    If Auto Answer is not set to on, press the arrow buttons until On appears, and then
    press to save the setting.
    Set the number of times the telephone rings before the printer automatically
    receives faxes:
    Press the arrow buttons until Pick-up On appears, and then press OK .
    Press the arrow buttons until the setting that you want appears, and then press to
    save the setting.
    When the number of rings you set is detected, the printer automatically receives
    the incoming fax.
    This should solve your problem.
    Thanks for using FixYa and for the great rating.
    hardrocko
    May 23, 2011 | Lexmark X5650 All-in-One InkJet Printer
    How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
    Sending a fax using the printer control panel:
    1. Make sure the printer is on and is connected to a working phone line.
    2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
      scanner glass.
    3. From the printer control panel, press the Fax button.
    4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
    5. Press Color or Black to select a color or black-and-white fax.
    6. Press Start to send the fax job.
    Source: Lexmark 5600-6600 Series Fax Guide
    May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    I have a Lexmark x5650 all in one unit. I can send fax but not receive fax. What do I need to do
    Make sure the correct phone line is connected to the printer and the correct fax number is set in the printer. This article in the Lexmark website will help you identify and resolve your fax problem: Fax Troubleshooting Topics
    Apr 16, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
    How do I change baud rate on Lexmark X5650 in
    May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
    Incoming Fax
    well to use the same phone *** home and fax might be the prob change the fax number that might be 95% of the prob the other 5% could be that it never noticed who its from ask a friend to send a fax and see if its working if not then go to my first advice
    Jun 23, 2009 | Lexmark X5650 All-in-One InkJet Printer
    Can send but not receive faxes
    Is that a USB connected Lexmark unit?
    Apr 24, 2017 | Lexmark X6570 InkJet Printer
    Lexmark x73
    Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
    About Distinctive Ring Pattern Detection (DRPD)
    "Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
    On the X125:
    Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
    On the X63:
    1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
    2. Press Options until you see Learn, and then press Start/Yes.
    3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
    4. Press Setup.
    5. Press Menu until you see Fax Receive Mode on the display.
    6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
    Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
    Lexmark X5650 All-in-One InkJet Printer Logo
    285 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
