Question about Ovens
Need a manual for a moffat oven
We have an old electrical moffat oven. The dial has worn out so that we cannot (and never got the chance to) read what the settings are, and it is not obvious to discern them via guess-and-check.
Would like to know where I can locate a manual/picture of the original oven so I can bake some bread.
ranger25
  • 72 Answers
SOURCE: GE Oven bake element not work
It sounds like a problem with the selector switch. You have to remove the back panel to get to the back of the switch in the head unit, and find what wire goes from there to the bake element. With a meter set on 240ACV, or whichever setting is on yours that's HIGHER than that i.e. 400ACV, with the red probe on the terminal and the black one going to ground, see if you are getting 210-240 through it. If so, then it's either a faulty neutral wire connection (the other wire coming out of the element) or the selector switch. Hope this helps.
Posted on Jan 29, 2008
SOURCE: Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Posted on Dec 08, 2008
  • 28 Answers
SOURCE: lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Posted on Dec 23, 2008
  • 412 Answers
SOURCE: Fisher Paykel electric oven doesn't heat in Bake mode
Check the Heating Element of your Oven.......
Posted on Mar 20, 2009
SOURCE: Moffat Self-Cleaning Oven will not self-clean
did you try setting a start and stop time with the time knobs? i had the same problem til i set 3 hrs on the start and stop, then let it sit (after locking the door and turning the knob to clean). after it was warmed to cleaning temp, the light for cleaning came one...
Posted on Jun 11, 2009
Where is the fuses located on a moffat stove
There are none. It is wired into the buildings electrical panel. You have to know where the circuit breaker panel is to find a tripped breaker
Aug 10, 2016 | Moffat E32 Full Size Electric Convection...
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
Feb 05, 2015 | Moffat Ovens
1965 Moffat Electric Built-in oven - model #21K90. No manual and no information on any of the websites I've searched. There is power (oven light, warmer light, rotisserie, power rack), but clock and...
My father solved this one, those clocks were such a hassle, ours buzzed for days til he fixed it. It requires opening the control panel and bypassing the wiring that allows the clock to turn the oven on and off. Of course you lose this function. Is that the complete model number?
Oct 26, 2013 | Ovens
While roasting a chicken in the oven, a "fizzle" was heard and the lower element shut off, the light on the dial did not work although it would go on when switching it to broil but there was still no heat,...
your heater element went (the metal rod that heats up inside oven). can easily find replacement and not hard to do but make sure you shut off power/ unplug oven. usually a couple of screws where the element goes into back of oven to hold it in place. then can pull element out enough to see the screws that attatch the wires the the element. most appliance repair shops carry them in stock. may be easier to take old one in to match up then trying to locate the make model and seriel number you would need wuthout it.
Sep 21, 2013 | Moffat Ovens
Oven rated for 208 voltage 220 volts available will this work or will I cause trouble
Yes it will work.Its nothing to worry. If the oven voltage is high and house old voltage is less then it will not work. But in your case its oven volt low and hose volt high.You can use it.Its a standard volt,you can use it. 'Most" equipment will work with a -15% / +15% voltage variance.--------- thanks.Helpmech.
Feb 05, 2011 | Moffat E32 Full Size Electric Convection...
I have Moffat E32ms 208V ,but my singal fase 240v. What I can do.
Those voltages are interchangable...you can hook it up with no problems...
heatman101
Aug 18, 2010 | Moffat E32 Full Size Electric Convection...
I need a operations manuel for and E32 moffat
Try this site. http://www.moffat.co.nz/Catalogue/SalesPDF/E25.pdf
If this isn't it let me know and I will keep searching. Hope this helps.
Aug 27, 2009 | Moffat E32 Full Size Electric Convection...
Moffat 3000 oven
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Oct 06, 2008 | Ovens
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Ovens Logo
354 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
