Question about Toshiba Satellite A135-S2276 Notebook
Windows has been shutdown to prevent damage to computer
I can not open windows in any mode, and it will not read disk. it keeps going back to the screen that tells me (a problem has been detected and windows has been shut down to prevent damage to your computer...........Technical information: *** STOP: 0x00000024 ( 0x00190203 , 0x862FB690 , 0x0000102 , 0x00000000 )
I need help, thank you
  • 1,223 Answers
Try restore ur system to factory default state when u purchased it as new u can do that as follows
from ur backup OS cd
or try this
BEFORE TURNING ON THE LAPTOP, press and hold the 0 (zero) button on the keyboard, then turn on the computer while holding the 0 (zero) button down. When the Toshiba logo screen appears, you can release the 0 key.
if the problem persists after this then i am 100% sure about hardware malfunction that is RAM problem kindly replace and check if it works or if u have two RAM chips installed try each one at a time to find the faulty one
Posted on Mar 03, 2009
  • Shoaib Rais
    Shoaib Rais Mar 03, 2009
    pls rate me FIXYA if i fixed ur problem
Power connection to computer came out during shutdown yesterday. Today, turning on, it will not boot up.
You are going to need a clean boot up disk. You will have to get one mailed to you or you will have to use another computer to download one. This will get you back into a point that you can do a windows restore. This is going to get rid of all programs and start you fresh. I do, however, feel that you disk drive is going out or already shot. You should do a Chkdsk on it. (check disk). This will tell you if it is a hard drive error or not.
Jan 09, 2015 | Computers & Internet
Write protected
Hi there.
I assume you are using Microsoft as an operating system.
You may need to run a filesystem check on the disk. Some times windows protects data by putting the disk in a read-only mode if your server/machines rebooted/shutdown unsafely.
Run it 2 or 3 times and you should be able to read and write to the disk again.
Dec 06, 2013 | Computers & Internet
Operating system not found
Hi there. The thing that caused the shutdown is a software conflict. Go to the windows advanced option by pressing F8 key when you see the Dell Screen upon restart of the computer. Choose "Disable automatic Restart in system error" and press enter. That should fix your problem.
May 18, 2010 | Dell Inspiron Mini 10 Netbook
The laptop tells me that one of the drivers is having a problem and it shuts down on its is an hp nx 7300
It refers to the Drives not drivers. It simply means that your hard disk have a lot of floating data files due to improper shutdown or hardware failure. So, to resolve this, windows shuts down to prevent further damage.
When windows open, open My computer. Right click on your Drive C and click properties. Click TOOLS Tab and Click CHECK NOW. Then schedule a thorough check.
Oct 05, 2009 | Computers & Internet
Desktop goes black/blank after opening
Can you go to safemode and check if you are able to see the icons.
Did you run a virus scan lately. If not you can try that.
Let me know the results and i can guide you further.
Feb 16, 2009 | Dell Inspiron 1501 Notebook
My computer shut down windows to prevent damage from my computer
Try tapping the F5 or F8 key (could be either one) right after you power up. This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
Sep 27, 2008 | Compaq Armada E500 Notebook
Blue screen w/msg: A promblem has been detected and windows has been shut down to prevent damage to your computer.
Youre probably going have to restore it. By doing that if there is a hardware issure it should be obvious by the installation process.
Sometimes a video card can go bad and cause this to happen. If you have another card laying around the house you might want to swap them and see if thats the case.
Jun 21, 2008 | Dell Dimension 3000 PC Desktop
For solving blue screen error
HP Notebook PCs - "Windows Unsafe or Sudden Shutdown" Blue Screen Error Occurs During Startup or Boot
Windows XP may not start and the following error message may appear on a blue screen:
This error occurs after Windows was not shutdown using a safe method. The notebook may have been turned off without clicking Shut Down or briefly pressing the computers Power button. The power may have been suddenly disconnected from the computer or the Power button may have been held for more than 5 seconds.
An unsafe shutdown can damage some of the Windows system files, preventing the computer from starting properly.
If the error occurs allow the operating system to complete a check of the hard disk. Windows will prompt your to run CHKDSK. CHKDSK scans the hard drive for damaged files and repairs the files if necessary. The scan may take up to an hour depending on the size of the hard drive and the number of damaged files. The computer will restart when the scan is complete and Windows should start normally.
If Windows will not start or the computer will not boot after the scan is complete see: HP Notebook PCs - Troubleshooting a Startup or No Boot Problem (In English)
use the link to know how to use recovery option with hp laptop
Thanks and Regard
Technical Associate
May 18, 2008 | HP Pavilion dv9000z Notebook
A problem has been detected an window has shut down to prevent damage to my computer
boot into safe mode by pressing f8 at windows boot time,
run a check disk by rightclicking the harddisk, properties, tools, check disk
check both options for file recovery and system file fix, click ok rebboot
see what happens and get back to me
use a bootable media like the windows system disk to enter the recovery console and run checkdisk from there
get back to me
Dec 14, 2007 | Acer Aspire 5630 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
189 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
