Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by Side is getting too cold on the fridge side.
I have a GE Profile Side by Side, model PSS25NGN AWW. I have the temp in the fridge side set to 37 degF, but it is cooling down to around 29 degF and is freezing the food. I adjusted the temp control to 42 degF, but it doesn't help. The fridge will still cool to around 29degF.
Any idea what is wrong? Is the thermostat bad or is there a door between the fridge and freezer that is staying open and allowing the cold air from the freezer to get into the fridge side?
Thanks
  • 1 more comment
  • darinfong99 Mar 01, 2009
    I have the same problem with my GE refrigerator. The food is freezing in the refrigerator side. An appliance part store sold me a temperature sensor and told me it would be located behind the control panel. But I removed the control panel and cannot find this sensor. Where is this sensor located?
  • matt_mizeur Mar 01, 2009
    I found the problem. The damper door was broke between the freezer and the fridge allowing too much cold air from the freezer to enter the fridge. Looks like I have to buy the Fan and Damper Assembly p/n WR49X10091 for about $90. What a rip off for a broken plastic door that should cost 50 cents.
    Once I removed the light shade from the top of the fridge, I was able to see the black damper door through the air vent and could tell it was loose inside the vent tube.
  • matt_mizeur Mar 08, 2009
    I also contacted GE this week and they are sending me a new fan and damper assembly. They also told me the cost was $130, but they would let me have it for $50. I went ahead and ordered it, but the super glue has been holding so far on my old damper door. There was an appliance store in town that carried the part as they see demand for this all the time, but they wanted $108 for the part. I recommend contacting GE customer relations if your damper door breaks as it will be cheaper than your local stores for a replacement part.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
    I found 2 thermo sensors on the wall adjoining the freezer. Now I'm unsure if I just pull the wire out of the little blue attachment or does the blue attachment come out as well with the wires.
  • darinfong99 Mar 08, 2009
    Thanks for the advice. The damper door was broken on my GE Profile refrigerator. I found this web site http://www.applianceblog.com/mainforums/.... It appears that these damper doors are a problem in GE refrigerators. I called GE and ordered the part. I also filed a claim because I lost so much food. They gave me a $90 credit. The part was to cost $130 and they charged me $40. The part took me 30 mins to install. It sounds like GE is aware of this problem. On the blog, people called to file a claim with the customer service dept and GE sent them money for the lost food. I also learned from GE that the control panel is a problem with the refrigerators. They might send that out with a discount. It was really surprising that GE was so helpful in customer relations especially in this economy.
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
FRIG DOEN'T GET COLDER THAN 49, WHAT COULD BE THE PROBLEM,FREEZER WORKS GREAT (GE PROFILE) ABOUT 2 YEARS OLD-
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The fridge is getting too cold.
what number u keep it on? maybe a new cold contol will be necessary
Jun 29, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Arctica Profile getting too cold, temp set to 37 actual temp is 25-35
Use the damper control to direct less air into the refrig compartment from freezer
Apr 23, 2017 | GE Profile PFS22 33" Artica French Door...
the dampener door in the fresh food is more then likely broke . allowing air in to the fresh food.
Jun 06, 2017 | GE PSS25NGNBB Side by Side Refrigerator
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
1,270 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
