Question about Reddy Heater-30-55,000 BTU Variable
I have a rllp35a propane heater and it will ignite
Ihave a rllp35a propane heater and it will ignite but when i release the button after holding it for more than 1 minute it will go out
  • 181 Answers
Either the thermocouple is bad or the pilot flame is not hitting the thermocouple .if the flame is hitting the thermocouple correctly it is most likely that it is bad and needs to be replaced
Posted on Mar 02, 2009
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
The heater wont start got power,got propane ,when i release the push in switch it wont start
YOU WILL NEED TO HOLD THE START BUTTON FOR ABOUT 2 MINUTES, ON YOUR FIRST START UP , TO GET THE FRESH GAS UP INTO THE UNIT
Dec 01, 2010 | All-Pro Propane Garage Shop Heaters - All...
I 50,000-85,000 All Pro Propane heater release red button fireout
If the red button has to be held down for a period of time to get the heater going it overrides the shutoff mechanism. If you are holding it the prescibed amount of time then either the hydraulic system which keeps your unit running is bad or out of place or the metering valve is bad. Check for a copper line with a bulb on the end. It should probably be in the fire created by the heater, if not bend it to be in the heat or very close. If this is ok then you may need to get a new burner for the unit which would probably mean buying an entire new unit as the cost would probably exceed the cost of a new unit. Let me know how you make out.
hardrocko
Feb 07, 2010 | All-Pro Propane Garage Shop Heaters - All...
Cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
Jan 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
I have a 35000 btu propane reddy heater that wont ignite .
the thermocouple is bad.it needs to send a signal to the gas valve to say it's okay to stay running.replace it and the problem should go away.if not let me know
Mar 13, 2009 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
207 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
