Question about Panasonic DMR-E85H DVD Recorder
Code u61 panasonic dvd recorder
How to reset
  • 88 Answers
Reset the unit as follows:
Press [POWER í/I] on the main unit to switch the unit to standby.
If the unit doesn’t switch to standby, press and hold [POWER í/I] on the main unit for about
10 seconds. The unit is forcibly switched to standby.
Alternatively, disconnect the AC power supply cord, wait one minute, then reconnect it
Posted on Apr 18, 2009
  • Robert H Mack
    Robert H Mack Nov 08, 2011
    still not coming on.
  • Robert H Mack
    still didn't come on.
I have a Panasonic DMR-ES15 DVD recorder. Fault code U61 is showing which is supposed to correct itself but is not clearing.
Only if it's worth it to you, if the unit was fairly cheap, no I would not recommend it, a new unit would give a brand new warranty making it more pleasing, since you had it fixed before it is time to replace.
Apr 21, 2012 | Panasonic DMRES15 DVD Recorder
U61
Did you try unplugging the recorder to reset it?
If that does not work, force a reset by holding down both the channel up and down buttons until it responds (about 10 seconds). Then reset the unit.
Nov 23, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Paqnasonic DVD recorder Model DMR-EZ45VEBS is stuck with error code U61, and now will not play any disk. Every time I insert a disk it comes up with the error code, Problem started whnI was recording a TV...
try cleaning the OPTICAL LENS directly with a Qtip , gently rub , try again , the code U61 means a self test procedure that the unit is running according to PANASONIC tech people, good luck , AJ
Nov 30, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
U61 ERROR ON DISPLAY
U-61 is a hardware error code. Usually means main board failure, however have found that a bad changer can also trigger that code since it connects directly to the main board.
Sep 21, 2009 | Panasonic DMR-ES35VS
ERROR U61
"U61" error message (there was a pwr failure or the AC cord is disconnected while powered on). Make sure all power connections are secure and your cord is in good condition. You might have to reset, maybe in manual
Feb 26, 2009 | Panasonic DMRES15 DVD Recorder
PANASONIC DMR-ES35V have error code U61
From User guide:
U61 • There was a power failure or the AC plug was disconnected while the unit was on. The unit is carrying out its recovery process. This process restores the unit to normal operation. The unit is not broken. Wait until the message disappears.
If fail unplug and hold power button for a minute or two and turn it on and repeat.
Error code u61 will not clear, unable to reset the DMR-EZ45VEBS
Hi, there was no solution to my problem with the error code U61, having talked to a Panasonic repair center it would cost £180.00 to fix this unit as the board and DVD recorder have to be replaced as one unit. It would cost me around £160.00 to buy a new one so there was no point in having it repaired.
Aug 04, 2008 | Panasonic Televison & Video
Panasonic DVD SC-RT70 whilst recording disc stopped and shows error code U61. Recovery process did not work message keeps repeating
I have a SC-RT70 model and there is U61 error code in my dvd player's display. what does this error means?
Jun 16, 2008 | Panasonic Televison & Video
Panasonic DVD/VCR message U61
Dear stds ~ My DVD Recorder Keeps Opening & Closeing The Tray A Gives An Error Message Saying ~ Repair Has Failed ~
DVD Recorder ~ DMR ES46V Panasonic ~
Error Message ~ U61 !
If Possible To Resolve ~
Please Do !
Before I Buy A New One !
Please Respond ASAP To ~ glvw@nyc.rr.com
Thanks !
May 22, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
U61 CODE WONT GO AWAY
I buy broken units reds repair 870-656-5139
Feb 10, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-E85H DVD Recorder Logo
381 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
