Question about Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw
I have milwaukee 6535 sawzaw that has no power it won't cut fast, touching the material stops the saw. what could be the problem?
  • l_lester6 Mar 01, 2009
    yes they seem fine that is why I'm confused...
  • Jim London
    Jim London May 11, 2010
    Hi, Have you checked the brushes?
  • 257 Answers
Hi, Well to be honest, I don't know either, not a typical failure mode. This model is equipped with several electronic features that could be at fault, which would require tearing it apart to troubleshoot. These saws do have a 5 year warranty and I think I would use it if possible. If you are unsure of the warranty period call in the serial number. 1800sawdust.
Posted on Mar 01, 2009
  • Jim London
    Jim London Mar 01, 2009
    Oh by the way, If I did make a guess, I would say that the gear protection circuit was at fault. Anything else would probably not let the saw run at all. Good Luck, sorry I couldn't Fixya!
How do you rotate the handle of the milwaukee super sawzaw
you can go to milwaukeetool.com and download an users manual for the tool. You would need the model number and serial number for this. Let me know if you need more assistance.
Dec 02, 2011 | Milwaukee Tool Saws
Just purchased a 6230 porta band saw and the blade keeps jumping off. Put the blade back on and as soon as you touch the material the blade jumps off.
could be a couple problems, first the blade could be bad, the tires that are on the wheels, a loose axle bolt or the frount housing might be bent. First try another blade and watch for which pulley it rolls off of. Next try to wobble the pulleys and if you can the axle bolt has loosened, I use an impact driver to lock them in place along with loctite. Next if the above are OK check the front housing for being bent (that is a common thing) from the housing hitting after cutting a piece of steel. Let me know if you need more assistance.
Oct 06, 2010 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Tripping 20 amp breaker
when things start overheating componants start to break down. sounds like you need to check the armature and field for burnt areas. at least change the brushes. were you bearing down hard? sounds like the motor may not be enough to cut quickly, maybe more slowly. hope this helps
May 07, 2010 | Milwaukee 6180-20 14" Chop Saw Abrasive...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw Logo
289 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
