JVC T-160 EHGB Hi-Fi VHS Tape
Problem for JVC T-160 EHGB Hi-Fi VHS Tape
JVC or Sony SVHS VCR?
By Grant - usenet poster
So after having my TR81 for about 4-5 months, I am ready to
make another "investment". This time in the SVHS VCR market.
I doubt that I'll have the same incredible luck price-wise
at a local store. So I'd like to go mail order route.
The two contenders I've narrowed things down to by reading the
news are: JVC 6700 unit vs Sony SLV-R5.
The major differences that I've noticed are: Sony has video
dubbing, has Control-L, has a way to display both VCR and camcorder
video in separate windows, and is around $200.00 more than JVC.
I've read good things about Computability. Any others?
I'd like to hear any comments on the relative merits of the two
systems. What's good, what's bad. Why would you get one over the
other?
Looking forward to all the great input.
thanks in advance.
- igor
Solution #1
posted on Aug 02, 2007
Somewhat Helpful)
Perkins
Rank: Apprentice
Rating: 0%, 0 votes
If I am correct, the remaining time information are derived by
measuring the rotational speed of the capstan which is unwinding the
tape. Provided that the diameter of the hub is fixed, it does not matter
whether it is T-120 or T-160 or any length. The manual does not tell you
to set any cassette length, does it? I have to agree with you that the
remaining time feature is really neat and I like it a lot.
Was this helpful?
Yes
No
Solution #2
Not Helpful)
Janice
Rank: Apprentice
Rating: 0%, 0 votes
I have a JVC HR-D970U, and my parents own a JVC HR-S8000U (I think that's
the model number). I'll say this much. I (nor my parents) will never
buy another JVC VCR again. I can't imagine another VCR that is more
susceptable to HI-FI dropouts. Mine is newer and the dropouts aren't
as bad as what my parents experience. At times, they can't watch a tape
because the audio is a scratchy sound for minutes at a time.
Il Hwan Oh |"...in Science, as in religion,
Univ. of Washington, Tacoma | when one has destroyed human wonder and
| compassion,
| one has killed man." -- Loren Eisley
Was this helpful?
Yes
No
Solution #3
Not Rated)
Pasty
Rank: Apprentice
Rating: 0%, 0 votes
I do not have the JVC 6700. I do have the 5800, however which is basically
the same unit only with a different remote. I also have the R5.
No, it doesn't bother me. Not in the least. I do a lot of editing from the
couch using the remotes. It is more convenient that way. Nevertheless,
the jog/shuttle on the JVC, while it will work in pause record, is not very
accurate. Therefore, it is kinda worthless for the way you want to use it.
Even with that capability, the JVC is less convenient to use for editing. I
also edit from my camcorder (Sony V701) and from my sony SLHF900 beta. I edit
also from the JVC to the R5. Why do I use the R5 as the record master while
editing? Quite simply because it is more convenient and does a better job,
IMHO. It is easier to use even without the record pause jog/shuttle on the
remote. The edits from that point are cleaner on the R5, also. At the time
I wanted the second machine, I couldn't get an R5. They were hard to come by.
That is why I got the 5800. It is an OK machine but ergonomically, it is not
very good. You have to flip the door down to do FFWD or REW but you can play,
stop, or pause from the front. You select the AUX input by using the jog
shuttle as a channel changer. AUX input is just under channel 2. Same for the
remote unit. The front inputs override the rear input. Unfortunately, there
is only one output from the machine. One rear input and one front input which
overrides the rear input. Inserting the S plug overrides the composite input.
Using the remote to program the VCR is difficult under some light conditions as
it is difficult to see the "AU" or channel number unless the light source is
at just the right angle. Using the on-screen menus to check your programming
is cumbersome, also. You can't get the list until you check the current one,
go out and come back to the menu from which you can select which program you
want to check. As I said, the wide body remote with my 5700 is cumbersome to
use.
Although the 5800 is not really a bad machine. The video looks good. I have
not had the tracking (audio) problems with this unit that I did with my 570.
The R5 on the other hand, has two outputs. One for a monitor with the effects
generator, and the other for dubbing without menus or any other unnecessary
video. The rear input and front input are independant. You have a select
switch to go from tuner-multiplex-Line 1(rear)-Line 2(front). I can leave the
L1 input on the switcher and plug the camcorder into L2 when needed. I can
edit between the front and rear inputs without unplugging anything. Now, that
is a handy meaningful feature which is more important than the jog/shuttle in
record pause. The keyboard layout is ergonomically better than the JVC. The
buttons are layed out together, logically.
Using the R5 and JVC5800 side by side for the last 6 months has me preferring
the R5 for editing. It is just a much more convenient machine to use.
I never use the time remaining feature. Never needed to. I know the tape
I have in and I know how much I've used. Remaining time has never been an
issue with me. BTW, Sony has been using real time rather for years on their
VCR'slong before the VHS decks started using them.
Yeah. Nice feature.
You get what you pay for.
5800 - Yes
Yes. Yes. Yes. No. - on the 5800
Yes Yes. No, Yes.
One. Yes it would but there isn't. You can program the VCR without turning
on anything, A/V or TV. There is a program feature on the remote which can
store 4 settings. I always program through the remote. I refuse to have a
VCR that requires looking at menus to program the thing. I have never used
the menus to program the 5800 or R5. The R5 programming is simpler. Makes more
sense, also. For instance, When you set the start time on the R5, When it
comes time to set the off time, it starts from the on time you set. The 5800
starts from wherever it was left at the last time it was used. I like the
toggles on the R5 better than using the jog dial on the 5800. The display on
the 5800 does not necessarily keep up with the dial. Quite often I must go back
to the previous choice and correct it after I have moved on.
Reasonably so. R5 is more reliable. Also, the accuracy on the R5 is better
than on the 5800.
Yes. Both 5800 and R5
Well, it is a VHS. The R5 has a high speed rewind (extremely fast) which
unthreads the tape. Otherwise, it is like their betas. High speed rewind
resets the timer, also.
As I said, my comments are for the 5800 which is basically the same as the
6700 except the 6700 has a newer slimmer remotebasically the same
as the R5.
Put both machines side by side and compare the panel and buttons. How are
they arranged? How is the remote arranged? What features are important to
you and how much are they worth?
Another thing I don't like about the JVC remote. When I am searching, if
I don't hold the buttons right, sometimes the machine locks in search mode and
won't release when I let go of the button. I must then press stop and then
start again.
Also, when using the JVC remote, If I am in play and press pause, if I want to
go into record pause, I must press both Rec and play to get it into record mode
and then I must immediately press pause, otherwise it starts recording. That
is why they need to jog while in record pauseso you can get back where
you wanted to be. The R5, while in play pause, you press rec and it goes
into record pause. Now, that is the feature I like.
Was this helpful?
Yes
No
Solution #4
Not Rated)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
In rec.video, (hon-chi.yu) writes:
My SVHS VCR (JVC777? I think) requires me to tell it if the tape is a
T160 or T120. It seems to be accurate so far for rental tapes. (Are they of
various lengths, or are they standardized?)
I enjoy my LD player much more than the SVHS feature.
Rob
/ / Robert Laddish AT&T: 707-577-3767
HEWLETT/hp/PACKARD HP Santa Rosa, Ca. Telnet: 1-577-3767
/__/ mail stop 4USQ
Was this helpful?
Yes
No
Solution #5
Not Rated)
Green1
Rank: Apprentice
Rating: 0%, 0 votes
(Robert P. Mech) writes:
<complaints about SLV R5 deleted
I'm planning to get a S-VHS VCR, too. I am mostly interested in the picture quality.
How does the picture quality compare for JVC-6700 and SLV-R5?
I didn't have any opportunity to see these two VCRs side by side.
Is there a difference between JVC-6700 and JVC-4700 as far as picture quality
is considered? I couldn't see any difference in the store, but I didn't
test the machines thoroughly.
And there is yet another VCR that I think I should consider: Hitachi 751A (or
similar). Has anybody got any experience with it?
Piotr Findeisen
Was this helpful?
Yes
No
Solution #6
Not Rated)
maartenw
Rank: Apprentice
Rating: 0%, 0 votes
In <076h02=
I also have been debating between the JVC 6700 and Sony SLV-R5. But I
have ruled out the R5 for two reasons, one of which I'm very surprised
no one here has mentioned.
On the three R5s that I have examined, the jog-shuttle on the remote is
*disabled* in record-pause mode!!!!!! It explicitly states this in the
owner's manual. I don't know about anyone else, but that's how I would
use the jog-shuttle on the remote 99.9% of the time, to remove
commercials or do other editing in record-pause. In fact, that is the
reason I'm considering getting a VCR with jog-shuttle to begin with.
And I can't use the shuttle edit, it isn't precise enough to get me to
the exact frame *quickly* when editing out commercials. I'm not aware
of any other VCR that disables the remote jog-shuttle in record-pause
mode. Some other VCRs have the jog-shuttle *only* on the remote.
Doesn't this bother any R5 owners out there? Am I missing something?
Because of this, I won't be considering the R5. (Would be far too
incovenient to use the jog-shuttle on the VCR).
The second (but not fatal) reason was a lack of a digital (H:MM) time
remaining display. The time remaining bar graph is utterly useless. I
can't use the elapsed time if I shuffle tapes in and out like I do when
taping Shuttle missions.
I'll have to say this about the Sony, the transport is incredibly slick.
Even has Skip-Scan. Made my RCA VR-695HF look like a model T. And the
PiP that pops up (main screen playback tape video, PiP insert live
video) when going into record-pause is also neat. Can move the tape to
the edit point while keeping an eye on the source.
So I'm leaning towards the JVC 6700, especially since people report it
can be gotten for less than $600. Nobody has complained yet about the
Hi-Fi dropouts that have plagued earlier JVCs, so I assume it isn't a
problem anymore with the new models. Since I haven't seen it in person
(nobody carries it around here), some questions for you owners out
there:
1) Can the onscreen graphics be *totally* turned off?
2) Is there a T-160 length setting for the time remain display?
3) Are the front and rear A/V inputs still tied together? If so, does
the front override the rear? Are there two S-video inputs? Or is
the only S-video input on the front?
4) Can one select the A/V input from the remote and when doing timer
recording? Can normal or S-video be selected, or does plugging in
an S-video cable override the composite video input? (Like it does
on my Sony XBR TV and RCA VCR , very annoying.)
5) How many A/V outputs are there? It would be handy if there were two,
so I can run one to my A/V receiver and the other to the TV, so I
don't have to turn on the A/V receiver when programming the VCR.
6) When doing edits while recording (go into record-pause, back up to
the desired point, then start recording again) are the edit points
clean? (No video glitches, pops in the audio, etc.)
7) Is the jog dial on the remote detented?
8) How is the transport? My one wish is to go from Record - Play without unloading and loading the tape. My RCA unloads/loads,
and this got very annoying after seeing what a full load transport
could do. Are fast forwards/rewinds done threaded or unthreaded?
It would be nice to go from FF/REW to Play real quick, but isn't
essential.
Thanks in advance for any 6700 info!
Robert Mech
Was this helpful?
Yes
No
Popular Solutions for JVC T-160 EHGB Hi-Fi VHS Tape
Questions and Unsolved Problems for JVC T-160 EHGB Hi-Fi VHS Tape
Do you recommend JVC T-160 EHGB Hi-Fi VHS Tape?
Answer
Answer
only got rte 1 rest of channels gone, got d-box2
Answer
Hi, The mains lead for my mothers Sony DAB radio XDR-S7 has got damaged and I need to get her a... (More)
Answer
Does anyone know how to best utilize this mic for live audio situations?
Answer
hello if got a dvd recorder with a dammage hdd i need the firmware for the panasonic dmr-eh65 can... (More)
Answer
Good Morning, I just moved into a new home with an M&amp;S System WH 35X for MC170, 300 or 370... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JVC T-160 EHGB Hi-Fi VHS Tape:
Top Audio and Video Media Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio and Video Media Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Best Audio and Video Media
Recommended by Owners
See more>>
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
