Question about Cameras
LCD display on minolta autometer 3 constantly blinking
My minolta autometer 3's LCD meter does not stop blinking. i've tried changing batteries and other settings but every time you hit the read button all the LCD screen does is non-stop blinking- without giving any reading. All the other functions work on the screen exept for an actual reading. It has not been dropped or subjected to any physical jarring.
I can't help but have the same problem! battery OK. Can change ASA/ Time but when I press button to take a light reading the display flashes for about a minute. did you ever find a solution?
Posted on Dec 27, 2009
Tourble code in 0510 in konica minolta bizhub 36
Do not continue to reset or a fire could occur and that would ruin a perfectly good day :) Code is for the FUSER!!!! (HOT PART) IF CODE COMES BACK replace the fuser
Start:
A. Call the service mode to the screen.(Shifting to the service mode is available even when the service call is occurred).
1. Press the Utility/Counter key.
2. Touch [Meter Count] on meter count display.
3. Press the following keys in this order.; Stop -> 0 -> 0 -> Stop -> 0 -> 1
4. Touch [Password], and enter the CE password using the display keyboard or the 10-key pad. Default is 92729272 (get three shots only then you are locked out)
B.Once in service mode use the following procedure
2. Change the screen using [?] / [?] and select [Trouble Reset].
NOTE
• The trouble reset key will be displayed in the service mode only when the service call is occurred.
3. Touch [OK] on the check screen.
4. According to the description on the screen, turn OFF the power switch, and turn it ON again more than 10 seconds after and check to make sure the machine operates normally.
Dec 27, 2013 | Konica Minolta bizhub C250 All-In-One...
Has verticle lines and turns off.
SONY LCD TV 32 inch, Display problems. Display half white colour.
Jan 20, 2012 | Sony KDL-32M3000 32 in. LCD Television
Whenever I touch the operating button to meter, the "under-range LED" will not stop blinking. No shutter speeds illuminate, not even the one I have the shutter set to. The only LED's that...
Be sure your mode dial is not in the auto position. If it is, the camera will only function with the lense also locked to the auto position, which will either be the lowest aperture (highest number) or sometimes an "A" setting separate from the normal aperture settings. That's generally what this type of indication means on program/manual models - that you're trying to use manual settings, when the camera is set up for auto program exposure.
Sep 08, 2011 | Minolta X-700 35mm SLR Camera
Low on oil ,added oil monitor won t stop blinking is there a reset button disconnected battery still blinking
The hour meter displays the total operating
time.
It will flash CHG OIL (Change Oil) at 50 hour
intervals. The flash duration is one hour
before and one hour after the interval. The
CHG OIL icon will come on and shut off
automatically. The hour meter can not be
manually reset.
Aug 09, 2011 | Husqvarna Zero Turn Mower Z5426
I connot remember the pasword to open reset code. it was an accident to ON the switching 2-6. THE PROBLEM NOW IS I CONNOT RESET THE CODE F36-1
I can give you a generic solution.... You did not give a model number. Some are different.... Is it a Konica or is a Minolta based copier???? Try this press the user choise botton then when then the display changes - press the meter count - then press Stop - 0 - 0- Stop. The display will change to Service mode.. That is if it is for your generic Konica Minolta copier.. Good Luck
May 02, 2009 | Konica Minolta Office Equipment & Supplies
Konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Nov 29, 2008 | Office Equipment & Supplies
Error c12co in minolta di550
C12CX (X is any value)
1. Run “Hard Disk Format” selected in the following sequence: Tech. Rep. Mode - Function - Image Memory.
2. If the same malfunction persists, change Hard Disk Drive.
3. If the malfunction is detected a third time, change Memory Board.
To enter Tech Rep Mode:
1. Press the Utility key.
2. Touch Meter Count.
3. Press the following keys in this order: Stop - 0 - 0 - Stop - 0 - 1.
4. Select Tech. Rep. Mode.
Oct 28, 2008 | Konica Minolta DiALTA Di200 Copier
Even when I immediately switch power source (AC adapter or External Battery Pack) right after the low-battery icon started to blink, the camera operation is still locked.
In cases where the blinking low-battery icon appears indicating insufficient power, wait approximately 8 seconds until the LCD monitor display and the EVF become blank. Then switch to another power source or replace with fresh batteries.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
Cameras Logo
249 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
