Question about LG LRFD25850 Stainless Steel French Door Refrigerator
I purchased a GE SS 22.5 CF Refrig. The doors do
I purchased a GE SS 22.5 CF Refrig. The doors do not align. Is there an adjustment? If so, how??
  • 10 Answers
Usualy there isnt a height adjustment most common problem is worn door cam due to over weighting door the door cam is made from hard plastic and is known to wear out even break
Posted on Aug 18, 2009
Refrig door not closing properly, needs a push,
DOOR IS NEEDING HINGE ADJUSTMENT. LOOSEN SCREWS IN HINGE, ADJUST DOOR TO ALIGN WITH SEALS AND TIGHTEN SCREWS TO RE-ADJUST.
Feb 20, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Temp and freezer adjust displays are blank with power on. m/n:psc23sgrb ss
Your display panel has lost communication with the main control board . Replaceing the board is the only solution . The main control board , is behind the refrig , behind an 8X10" panel . Pt # WR55X10942 . Easily replaceable due to the 6-7 group plug ins , will only fit to certain recepticals ( with the same amount of pins in the same amount of recepticals ) . Be sure to unplug the refrig when replaceing .
Aug 31, 2010 | GE Refrigerators
. I need the hinge door stop on the lower right side of refridge
The door stop part # WR02X10782 If this is for the refrig door , check the screw at the bottom of the door , to make sure it is not adjusted too high , bypassing the door stop . The same door stop is used on both doors .
May 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator does not get cold. Freezer does. 3.5 cf.
check the eoor gasket it may need to be replaced. The door may be out of line(not closign snug) you may have to lossen the screws holding the gasket on and line the door. a hint hold the bottom of the door with your leg or foot and **** lightly on the top of the door. That how we do a quick adjust
Apr 21, 2010 | Frigidaire FRT17G4B Top Freezer...
My GE SS Side by Side Refrigerator is not dispensing water; makes ice just fine. Is this a problem that I can fix without a service call?
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . GE also has a dispensor heater , to help keep this from happening again , if , the water line is frozen . Pt # WR49X10173 .
BB ..... refrigerators are not your AoE .
Dec 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
RE: GE model #gsh25jsrf ss. The water does not dispense from door. Can I fix this? Thank you.
Oct 31, 2009 | GE GSH25JFR Side by Side Refrigerator
Adjustment of the fresh food door.
Normal for freezer door to be slightly higher, The upper hinges can be adjusted to make minor changes and raising the front roller under the rlower door will(or lower the higher side) help align them. It is a trial and error adjustment that takes time to get the best compromise of door alignment to cabinet setting.
Eric
Oct 16, 2009 | Refrigerators
Ge side by side water will not come out of door dispense
The water switch went bad or the water valve. Switch the two wires on the water valve on the back of the ref. Press water switch on door if water fills ice maker valve is bad,if not,door switch is bad.
Jan 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
LG LRFD25850 Stainless Steel French Door Refrigerator Logo
207 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
