Question about Gaggia 16002 Espresso Machine
Gaggia 1600 - Pump noise stays loud; no flow
Gaggia 1600 - Pump continuously makes a loud noise. Water does not flow to brewing head. Steamer works fine for both steam and water. Has been cleaned regularly. Not quite 2 years old. I am about to toss it and go back to stovetop manual brewing
  • 80 Answers
Change pump
Posted on Aug 01, 2009
  • 5 Answers
SOURCE: gaggia classic -no steam from spout
I had almost the exact same thing. The fuse for your frother is out. If both the frother and the brew head won't heat, then it is your Thermal Fuse. There are two different fuses inside the machine. Take the top off, and find both fuses. Take a piece of wire and connect it to each end of the fuse. Now turn the power on. If it heats, then that is the fuse. If no results, try the other fuse. Either fuse should be cheap. My thermal fuse was $1.98. Good luck!
Posted on Jan 14, 2009
  • 1089 Answers
SOURCE: gaggia syncrony compact is leaking. Removed top
Hi What color is the steam manifold? It is located under the black cover with the trough in back under the whit tube. If its whit or black it probably needs to be replaced. If you cool down the manifold after steaming you can prevent this from happening. Just turn off the steam and then open the knob again to run water. It comes out steam at first but then will turn to a water stream. Then you can close the knob and go about brewing or just let it stand.
Posted on Jun 14, 2009
LaPavoniBoy
  • 36 Answers
SOURCE: water wont flow past brew head
Hi there, it sounds like your boiler may be full of scale. There is a copper tube which runs from the group up inside the boiler which can get clogged up quite easily. When you take the group apart you will see that when you remove the shower plate and unscrew the bolt in the middle the safety valve and spring will pop out and then if you get a pipe cleaner or something similar and ram it up through the copper pipe. If this does not work then you may have to dimantle the boiler and give it a good clean out. Also although you say the pump is primed it could still be broken. All these problems usually come from scale though. If you get some descaler and try to feed into the boiler by pumping or running water out the steam wand this may free it up. Any further assistance please get in touch with David at coffeeservice@live.com
I am a domestic coffee machine engineer and have machines of all makes sent to me from all over the UK daily. I specialise in La Pavoni, Gaggia, Elektra, Francis Francis etc. You can get in touch with confidence.
All the best
David
The Domestic Coffee Service.
Posted on Jul 08, 2009
McLindy
  • 32 Answers
SOURCE: no water coming through the head after prime etc
I have the same problem. I disassembled the unit body from the boiler. There was some scale, which I cleaned out. However, everything was flowing through the orifices with gravity -- no need to use a pipe cleaner because nothing is clogged.
So then I started tracing the flow of water. There is only one thing between the boiler and the shower head: the solenoid valve (in diagram ER0182 part # 27).
Sure enough, the solenoid valve will not accept water through the orifice that would route it to the shower head. Of course, this is with the solenoid unplugged and removed from the system. I soaked the orifice end of the solenoid valve in some decalcifiying solution in the hope that the solenoid piston may be jammed with a bit of scale.
Now I'm going to reassemble and hope for the best. However, my guess is that my solenoid valve needs to be replaced. Everything else is working (pump, valves, tubes, etc.).
I will report back.
Posted on Aug 07, 2009
  • 1089 Answers
SOURCE: We have a Gaggia Syncrony Logic that is just over
Hi
Check the drain behind the brew unit. There is a pocket below the injector that can plug up and cause water to drain under the drip tray. Check this first. Stick you finger in the pocket and see if there is water in it. If there is, the drain below and to the right is plugged and just needs to be cleaned.
Posted on Dec 11, 2010
Testimonial: "Indeed, it appears the pocket below the injector was plugged. Was able to clear it and it now drains properly. thank you!"
Brew switch not responding
your not far,
test your switch with a test light
or you could always jumps the wire direct to your pump
if nothing works check for parts on ebay.
Jan 06, 2014 | Gaggia 102534 Espresso-Color...
Mr Coffee Pump Espresso machine not working. Lights alternately flash between coffee and steam icons, machine makes noise, but coffee does not brew, water does not flow, steam does not come out.
The espresso portion may be clogged with hard water deposits, and the steamer tube with casein. Run a tank of plain white vinegar a couple of times then run a couple of tanks of plain water to flush the vinegar, Open the steam valve while the espresso portion is running and set the steamer pot under the steamer. Don't be surprised if a long white tube of hard white material slides out of the steamer valve. That's the casein, actually a form of organic plastic.
Sep 27, 2013 | Mr. Coffee Coffee Makers & Espresso...
Gaggia titanium - between cups of coffee, we leave the machine on. After only a few minutes, the machine makes a loud clicking noise, and then the noise speeds up. A very loud, clicking noise, very...
Hi, That loud noise is the pump, pumping without water running through it. Thats not good. Will do expensive damage to whole machine if let go. It needs flowing water to stay operating for a good life. Already sounds like an ECU board. It may only be trying to rinse itself, but is cloged, and cant get enough water into it. It needs to be looked at by a repairer. I can helpyou there if you live on the sunshine coast. Dazza
Aug 21, 2011 | Gaggia Titanium Espresso Machine
Water for steamer but no water flows to make coffee
Remove the screw and shower screen under the brew head, make sure screen is clean, try running the head to see if water flows, if no water remove allen wrench screws, and check spring and valve seat, DO NOT LOSE SPRING AND VALVE. Try running head, if water does not flow, reassemble and descale machine.
Sep 10, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Have a baby gaggia coffee machine and unable to find anywhere that will service or repair. The machine has worked really well for 3 years but now is making aloud noise when working and the flow is very...
The loud noise is coming from the vibrating water pump.
One posibility is that is full of scale or and dirt so you can try descale the machine.
Second is probably the water tank can fit corectly on the base and the valve on it does not open correctly or not at all so the pump it can not s**k water but air or a mix of them so we have the loud noise.
Finally you can remove the shower disk on the group head , locate above where you place the filter holder and clean it probably is full of dry coffee and block the water way out.
Please note that can be all above problem together.
Good luck
Mar 27, 2010 | Gaggia Baby Espresso Machine
Light switch is on but after warm time try to press for coffee nothing happen, the machine is clean, full of water no flashing of lights as normal but light is on. Try the steamer for cappucino and its...
The brew head might be blocked, remove the scrfew and screen and clean the shower, before replacing them try turning machine on and running the head if water flows then screen needed to be cleaned if not then the blockage is higher in the machine and you will have to remove the 2 allen wrench screws to remove the diffuser and check the valve and spring in the head.
Nov 11, 2009 | Gaggia Baby Espresso Machine
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Water wont flow past brew head
All the best
David
Jul 06, 2009 | Gaggia Classic Espresso Machine
Gaggia evolution- water doesnt flow through the brewer
Make sure your filter in the machine and in the filter holder is clean, the filter in filterholder there you will see a little light in the middle if you head it to light, else you have to replace the filter.
Feb 23, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
No water coming through brewing head
Hi there, I had a very similar problem with my Gaggia Classic. Worked fantastic every day for two years then one day the brew head was reduced to a very slow drip. I rang some Gaggia service agents and they all said it needs a service ($100-$150). The last one I called told me to descale it before bringing it in for a service as it was probably scale buildup. I told them it wasn't a gradual thing - it just suddenly stopped and they said what happens is the scale builds up to a point where a piece breaks off and clogs the pipeworks leading to the brewing head. So, I used the instructions outlined here: http://www.coffeemachine.com.au/descalin... At then end of the second flush through the steam head, I closed the steam vale to try and push the descaling solution back through the brew head (just dripped through again) then left it for 10 minutes again. Did the same the third time and it went to drip again for about five seconds then bingo - burst back to full flow. Hope this helps.
Jun 02, 2007 | Gaggia Classic Espresso Machine
Gaggia 16002 Espresso Machine Logo
1,128 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
