Question about GE Profile PDW8400J Built-in Dishwasher
GE GLD5500 Dishwasher blinks and beeps, will not respond to reset
I have tried the reset button and flipping the breaker. No response. The pots/pan light and heated/dry light blink constantly and it contiues to beep. I had steady lights before I shut off the breaker and turned it on. Any suggestions?
markevans
  • 148 Answers
SOURCE: lights on pots and pans blink constantly
try disconnecting power for a bit. try the cord under the sink. if its hard wired (no cord) you can try the breaker.
may reset itself.
otherwise, you have a logic board issue.
consult the manual first for explanation of blinking lights etc.
then call the mfg for further info and if needed, schedule an approved repair person.
good luck
mark
Posted on Dec 28, 2007
SOURCE: blinking lights on control panel
Same issue, machine is about 30 days past waranty. Door switch broke, but of course they (GE repair) do not fix the switch, you have to order the Escutcheon Body (whole panel) to fix ~$350 total.
Posted on Aug 04, 2008
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
  • 12 Answers
SOURCE: pots and pans and normal wash blinking
Try resetting it. Locate the switch in your breaker box, and flip it off- then on again. Hope that works!
Posted on Aug 09, 2009
heatman101
  • 43501 Answers
SOURCE: linny4242@aol.com My problem: I have a
It sounds like the main control board has gone wacky....
replace the control board
. That is not that hard to fix and you can easily buy the partsyourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 20, 2010
Pushed button for pots & pans and now it won't cancel, what can I do?
Hi Teresa, Step 1
Press and hold the "Start/Resume" button on your dishwasher. This button controls the power for the entire unit and will force a reset of the system.
Step 2
If this does not reset the dishwasher, shut off power to your kitchen using your home's fuse-box. If dishwasher is a built in unit, ie: in a cabinet, this is the easiest method. If your dishwasher is not built-in, you can unplug it from the wall.
Step 3
Flip the circuit breaker switch back on, restoring power to the dishwasher.
Step 4
Press the button again to start up the unit. Whether you reset the system by pressing the button or cutting off the power, you'll need to press the "Start/Resume" button to power the unit back on afterward. Diagnostics will run again, but after a forcible reset, the diagnostic cycle usually proceeds without incident. I hope this helps. David.
Oct 05, 2017 | Dishwashers
Pots and pans light, quick rinse and cancel buttons all blinking. unit will not start.
Try to pull the fuse or turn off the breaker for 30 seconds. This should reset the electronics and possibly fix the problem.
Sep 08, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Pots and pans and normal wash blinking
Aug 09, 2009 | Kenmore 13743 Staimless Steel Built-in...
The Pots Pans button flashes and won't let me change it
Go to your circuit breaker panel and turn off the circuit that feeds you dishwasher. Leave it off for three minutes. This will reset the program and should solve your problem.
Apr 04, 2009 | Kenmore 15634 Built-in Dishwasher
All 4 lights on my haier dishwasher Model CG206B blink and beep.
I had the same thing the drain hose was plugged.To reset You have to tilt the washer back 45 degrees.Mine is now running hope this helps.JIM
Jan 04, 2009 | Haier ESD200 Built-in Dishwasher
Lights on pots and pans blink constantly
may reset itself.
good luck
mark
Dec 21, 2007 | Kenmore 24 in. 17482 / 17484 / 17489...
Ge quiet power 3 dishwasher
According to the GE repairman who visited, the solution is to close the machine (with the lights flashing). The machine starts and goes through the cycles, which it does rapidly and then all the lights turn off and the machine becomes silent after 1-1/2 to 2 minutes. Then the machine has been reset to normal. During this reseting period nothing happens inside the machine, although you may hear a running sound.
Thus, the solution is to run the machine in this flashing light state for the 1-2 minutes it takes to go raipdly through each cycle and then reset.
I hope this helps.
Oct 09, 2007 | General Electric Adora GHDA670N Built-in...
GE Profile PDW8400J Built-in Dishwasher Logo
314 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
