I'm a new user with canon d50.i have set up manual function at mode dial.I tried to go and learn more about menu procedures.I pressed unfortunately the live view. After that i can't find the view after taking photo but when use flash than image appear on LCD.I think something wrong with white balance or F stop. Please help me out to get into it with your more information.
Yours sincerely
Tsewang Gonpo
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Hi, It is known problem of ccd imager chip failure in few Canon models and your S2 IS got that problem too, ccd imager chip will be replaced to get live view in camera mode to take fresh pictures. Local camera repair shop will help you to replace ccd imager chip in camera or click Canon CCD Imager Support and talk to them if they can replace it for free. Hope this info will help you. Thanks.
HI there when you go for click the image that time on your LCD screen. Right now its off and its in viewfinder mode. So press the switch for LCD on so , you can see the image in LCD in camera mode. Thanks.
It sounds like your camera has the review time setting set to a short value like 1 second. Look in your user manual for Review Time and then follow the steps to change the review time setting on your camera. If this doesn't solve your problem, it would help to know:
1) Do you have your user manual? 2) What do you have the Review Time set for? 3) If you go to playback mode can you see the picture for a longer time?
You need to enable the "live view" mode in the menu, then "set" live view as needed. When you are in this mode the shutter is open and the lens is flipped up to allow the image to hit the sensor and then to your preview screen. Because of this, the camera can't auto-focus, but there is an over-ride mode.
Hi, Prepare to Live view shooting: 1. Set the lens focus mode (on the side of the lens) switch to <MF> 2. Set the shooting mode to a Creative Zone mode 3. In menu under the settings tab, select Live View function settings and then press <SET> 4. Turn with quick control dial to select Live View shoot and press <SET> 5. Turn with the control dial to select Enable and press <SET>
With the camera ready to shoot, press <SET> - image will appear on the screen in real-time
Check the card isn't set to write protect mode with the switch on it.
I will assume the picture is viewable through the LCD and everything else appears to be normal.
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
