I try to upgrade Firmware of paradyne 6381 a2 but I don't wait to complete upgrade and reset my modem .then modem not bootable .
what i can write Firmware on my modem when it not actived
SOURCE: Cannot access my modems home page.
Nore than likley that is the default LAN IP address that came with the device. It has probably been changed during the initial setup. A quick way to tell is go to your start button/ select run / type in the run box CMD / this brings up a dos shell in the dos window type IPCONFIG and hit enter.. Note your IP address and your default gateway.. " the default gateway is your device in question. make sure your IP address matches your gateay with the exception of the last 3 octects. so it should read something like this
IP Address 192.168.1.50
Subnet mask 255.255.255.0
Gateway 192.168.1.1
My guess is that your not on the "1" network but the router is handing out a different range of address if that is the case in the dos window type ping (the ip address of your default gateway)
like so ping 192.168.X.X where X = the octet values of the default gateway listed in the dos window
If it replies then your talking just fine you are simply trying to access your router via the wrong IP so take the IP of the gateway listed from the ipconfig command and put that number in your browser.
If this is not the case then we need to go in a different direction with this.
MilToN
CNA,CNE,MCSE,CCNA,Network +
SOURCE: hey
check if your computer is getting a valid address from your modem. if so, try to ping the modem's address and check if you'll have replies. if it'll reply, try to disable any antivirus software and firewall installed on the computer or try to use another browser. if not, check i the computer is properly connected to the modem, try to use another port or another known working cable. also try to use another computer for isolation.
hope this'll help you with your concern.
during the upgrading the firmware of paradyne 6381-a2 power was down.When the power is come then i try to open / access the 6381 modem but he can,t accessable and modem lights is not working properly.
I trying to update firmware of my paradyne 6381-a2- modem, before complete the process the power was down and all the process closed. when i try to access the modem again but the modem is not responding / accessing , but modem lights too not working properly. I m very upset pls tell me the solution of this problim.
