Question about Acer AL1715 (Black, Silver) 17" LCD Monitor
Why does my Acer monitor display OSD LOCKOUT whenever I start up?
    Brigadier General:
  • 5,158 Answers
Hold the power button for a few seconds it should say osd unlocked.... if that doesn't work unplug the monitor for a minute or so and plug it back in.. that should fix it
Posted on Mar 01, 2009
Monitor display says OSD Lockout /no signal input how to fix this?
This document pertains to LCD monitors .
One of the following messages appears on the screen (over the items being displayed).
OSD Lockout
OSD Lock-out
... or similar message.
This message occurs when the Menu button on the front panel is pressed for more than 10 seconds. OSD lockout prevents the OSD menu from opening on the screen when a button is accidentally pressed.
NOTE: The button may be different and the procedure might vary on some monitors. Please check your monitor User Guide to find the exact procedure if this procedure does not work.
To remove the OSD Lockout message, release the Menu button (if something was pressing against it), and press and hold the Menu button again for about 10 seconds - until the message goes away. If the OSD Lockout message does not go away, the button may be stuck or the hardware behind the button might have become defective.
Aug 31, 2013 | Dell Computers & Internet
Brightness/contrast locked
All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on-screen display (OSD) lockout that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lockout setting, there are several ways you can remove the lockout.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout. Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears. Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings. Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
Mar 02, 2013 | Dell Inspiron 580 Desktop Computer...
An OSD message appears in a box that covers much of the monitor screen. The mouse pointer disappears behind the box whenever I try to sweep into it. The box will not go away (except intermittantly)...
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
Dec 29, 2010 | HP Computers & Internet
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
Osd lockout
osd is ON SCREEN DISPLAY.
Jun 10, 2009 | HP w1907 LCD Monitor
OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Nov 02, 2008 | Computers & Internet
OSD Lockout
Have you opened the monitor's onboard menu and checked the OSD settings? Do that and see if you can change those settings there. I would also open the Device Manager and check for problems. If you see any yellow question marks, that hardware has a problem.
Sep 12, 2008 | Acer AL1715 (Black, Silver) 17" LCD...
Acer AL1715 (Black, Silver) 17" LCD Monitor Logo
665 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
