Question about Abit IS7-V2 Motherboard
ABIT IS7-V2 - Can't boot from CD if HDD is present.
Hi all. I am having an interesting issue that has escalated. I have had problems before loading WIN onto this motherboard in as much as if my 6GB drive is hooked-up and defined in CMOS, the PC will not boot from the CD. I thought it had something to do with that drive, so I have moved it to the 'slave' and installed another HDD as the 'Master', but I still can't boot & install WIN from CD, as long as they are defined in CMOS. I have boot sequence setup to only use the CD drive - when I have HDD defines in CMOS, I get and error stating that it cannot boot from the CD. But, if I have HDD hooked up but not defined, it will boot from the CD fine. In the past, with the 6GB drive as the only HDD, WIN would recognize that the HDD was there during the installation and then it would become defined in the CMOS. Any ideas?
  • jcr_trains Mar 09, 2009
    I solved the problem. The system would not recognize the USB keyboard, so when I hit a key in response to the 'boot from CD' question', it was ignoring it. I replaced it with a PS/2 keyboard I had, and now I am able to boot from CD. .
    Thanks!
  • tommyboyFXP May 11, 2010
    have you set the SATA ports to ide mode manually in the bios? (i presume it's IDE as only 6gb). What type of optical drive is it? IDE or SATA?
5 Suggested Answers
revskank
  • 203 Answers
SOURCE: Abit IS7-E2 monitor wont display anything
is this a brand new motherboard?
do you have onboard graphics or a card?
without testing i couldnt say for sure but it sounds like you are not getting power to your graphics on motherboard.
this is usally a common issue for asus motherboards. not easy to fix.
if your motherboard is new i suggest a replacement from the seller.
Posted on Feb 25, 2009
venexcsd
  • 1185 Answers
SOURCE: i want to define motherboard
Open up the link below , go to their support section , type in the number of your motherboard and they should supply you with an installation manual
www.biostar.com
Posted on May 24, 2009
  • 263 Answers
SOURCE: high defination audio bus drivers
Mke sure you have uninstalled theold driver first and restart ,windows should say found new hardware ,then try install,good luck John
Posted on Aug 02, 2009
guitarmanjoe
  • 336 Answers
SOURCE: abit is7-v2 cmos checksum error
Have you replaced the battery?
Posted on Mar 15, 2013
Abit is7-v2 cmos checksum error
Mar 14, 2013 | Abit IS7-V2 Motherboard
HOW DO I KNO WAT WIRE IS POSITIVE WEN HOOKING UP TOWER CONTROLS TO MOTHERBOARD
The connector and motherboard usually have a RED color/wire for positive or be marked with a + sign. If you don't have the manual for the motherboard you can get one by going to the abit site, under support or download and entering your model number.
Aug 16, 2011 | Abit IS7-V2 Motherboard
I didnt have any problems but i went to turn on the computer and the computer beeps one time then beeps again there is no patter just long beeps one after another what is going on!!!?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 02, 2010 | Abit IS7-V2 Motherboard
I installed everything the CPU, RAM, and everything else. Connected all switches at the right places and the BIOS is on normal operation. I turn on the computer and its a blank screen nothing shows up....
ok, looking at the specifications All I can recommend is the following. double check the Video card to make sure it is properly seated and that it does not exceed the capabilities of the motherboard. 2 Disconnect everything from the motherboard except the CPU and case wiring/power supply and turn the computer on. If the system completes the post test, you will hear at least 1 beep and should hear several for the video card not being connected, then start installing components 1 at a time till you find the one causing the problem. Start with the Video card and then the ram as these are most likely where your problem is unless you have a faulty power supply which will be the problem if you don't get a completed post with nothing else connected.
Jun 18, 2010 | Abit IS7-V2 Motherboard
Abit is7-e2g shuttdown
observe the CPU temperature,
it could be a heat issue,
try to reseat your heatsink then wipe the old thermal paste and put a thin layer of thermal paste
hope this thing helps
Jan 31, 2010 | Abit IS7-E2G Motherboard
Hey guys would you be so kind to try to help me out? a friend brought me a pc with an abit IS7 motherboard it can't boot instead, all fans start working then a red light, 3 short peeps and it stops. What...
The beeps might indicate the problem with RAM. Try plugging out the RAM modules and insert them back in one by one in different slots and then check.
Jul 17, 2009 | Abit IS7 Motherboard
Feb 24, 2009 | Abit IS7-E2 Motherboard
No ethernet driver for is7-v2 in xp/vista/w7
Take a look here:
http://www.abit.com.tw/page/en/download/download_driver_detail.php?pFILE_TYPE=Driver&fSEARCHTEXT=is7-v2
Be sure to also install the chipset drivers, if that is missing it would explain why so many things do not work. If they still do not work after installing these, I would recommend returning it to the store and getting a replacement, it could be a lemon.
Feb 03, 2009 | Abit IS7-V2 Motherboard
ABIT is7-vs no ethernet
Have a closer look ... that appears to be in IS7-V2 board
http://www.abit.com.tw/page/uk/motherboard/motherboard_detail.php?pMODEL_NAME=IS7-V2&fMTYPE=Socket 478&pPRODINFO=Driver
If the link doesn't work right you may have to copy and paste the entire link into your browswer
Download the Realtek Lan driver you should be good to go
Robert
Please take a moment to rate this solution thank
Feb 03, 2009 | ASUS P4B533-VM Motherboard
Need help
if you have more than 1 device on the ribbon cable, make sure they are both on CS(cable select) or one is on master and one is on slave.
Next disconnect all the drives from the board and just hit the del key to enter the BIOS. Select advanced tab to make sure SATA is active, otherwise you will bypass any sata and go only to ide channels.
Once the sata is active, check boot sequence and select CD/DVD as 1st boot priority save and exit, on the reboot turn unit off and attach all cables to the board. Reboot.
Mar 19, 2008 | Abit IS7 Motherboard
Abit IS7-V2 Motherboard Logo
89 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
