Question about Canon FAX-JX200
Fail to make our new fax machine work well
Please let us have full instruction to make our fax working well
What are you asking? Work well? print quality problem? error message? My crystal ball is in the shop.
Posted on Mar 01, 2009
Where can i find assemble instructions
You've repeatedly posted this question. When you post again, please specify exactly what "the curio" is. Brand and model?
May 11, 2013 | Office Equipment & Supplies
I have an SCX-4521F and suddenly I cannot send or receive a fax. There is notification that a fax has been sent to me, but it does not print. When I send a fax, it tells me there is "no answer"...
Hi, I am Steve and I and going to help solve your issue.
I am going to start with the 2 simple things that may be causing this. Please accept my apologies if you have tried both of these solutions. If you have please let me know and we can go on to more advanced troubleshooting.
As the machine has suddenly stopped sending or receiving faxes I am assuming it was working prior to this issue.
The first thing to check is whether the machine is still setup to enter fax mode. the best explanation for this is directly from the Samsung support - click here for the instructions on ensuring automatic fax mode is enabled.
alternatively the memory could be full. again I am going to use the Samsung support site instructions to help you clear the memory - click here for the instructions and you want to clear the fax memory (option fax feature) if this does not work it may also be worth using fax setup and advanced fax - these will reset the fax machine to its factory defaults.
Please let me know if these solve your issue, if not we can move onto further troubleshooting?
Jan 13, 2011 | Samsung SCX-5115 Fax Machines
Getting error message: "Ink system failed; error: Oxc18a0306. The manual does not cover this. How can this be corrected, or is it a fatal breakdown? Gene
Please perform these resets if not work go for a new all-in-one.
1.
Press & hold the power button > unplug the power cable from the back of the printer while holding the button for 30 seconds > plug the cable back then release the button.
2.A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Jul 27, 2010 | HP Photosmart C6100 All-In-One Printer
How i could use it as a fax mashin
it actually depends on the fax machine itself but it basically works like
u press pause and then type in the fax number and press send but that is only for certain fax machine in order to tell you the full instructions type in your machine into the manufacturers website and look up the instructions
hope that can at least help a bit!
Jul 15, 2010 | Samsung SCX-4216F All-In-One Laser Printer
How fax says File full and will not fax any docs. How do we fix?
First I would plug a regular phone into the phone line to make sure it has a dial tone. Assuming that works send a fax to your cell phone and see if the fax machine dials out and makes your cell ring. Assuming that works check the fax for an error code as to why it is not faxing or failing.
Feb 11, 2010 | Panasonic UF-4000 Printer
Fax will not recieve or work.
hello sir; is this unit brand new? If yes , check the phone line from wall to the machine did you plug in the jack it said "Line" on the machine. if that's old machine, please change a cable see what's happen.
Dec 29, 2008 | HP DeskJet F4280 All In One Printer InkJet
Phone line goes to fax, then ans mach...now caller ID won't work.
Set the reception mode to Fax with answer machine TAD. Make sure its set for fax with answer machine.
May 29, 2008 | Brother IntelliFax-2820 Laser Fax
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Brother intellifax 4100 prints full page all black
Good chance the High voltage power supply is bad. Not worth repairing. A new unit costs about 259.00.
Aug 08, 2006 | Brother IntelliFAX 4100 Laser Fax
Canon FAX-JX200 Logo
42 people viewed this question
old marine
old marine
