Question about Denon S-101 System
Denon s101 - standby light keeps flahing
When switched on the system seems to power up but the standby light just keeps flashing orange and no display comes on.
  • hanyst Apr 24, 2009
    The problem is it doesn't power up but the power light button flashes when pressing it or pressing the play button.
    I checked the 2 fuses inside the Boom Box and they r good. There are no fuses inside the player though.
    Help please.
    Thanks,
    Hany
    Cell (310)291-6899
    hanyst@yahoo.com
5 Suggested Answers
  • 196 Answers
SOURCE: unit automatically switches off
Maybe all you need is to dust off the DVD player's pickup. I have had this happen several times with several players. After dusting the pickup, those players are still in service.
Posted on Feb 15, 2006
  • 6 Answers
SOURCE: Denon AVR-1508
sounds like overload protection
turn the volume all the way down, then turn it on
if that doesn't do it you may have a short in one of the speaker lines - try disconnecting them one at a time
Posted on Jan 13, 2008
SOURCE: denon avr-2106 problem!!!
You're drawing too much power from it. Sounds like maybe your sub is hooked up wrong, double check that.
Posted on Jul 06, 2008
Foxyjay
  • 13 Answers
SOURCE: i have a denon AVR-2105
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
SOURCE: Denon AVR-1705 won't power up
when i turn it on it stays on for 3-4 seconds then shuts down
Posted on Oct 16, 2008
I have a Denon avr 2801. My standby light is flashing and i cant seem to reset it. I have tried pressing the a and b buttons together and then turning the power on, all the lights flash but thats it.
Hello
There is always a constant 5v for the device to go to standby.and power on when you press the power button .
This flashing is not to reset the device it shows that there is a problem with power supply.
the regulators are burned or over voltage ...
it needs service .
hope this helps
good luck
Jan 20, 2016 | Denon Audio Players & Recorders
Denon not switching on
Talk to Richer Sounds hi fi there will be a shop near you if you are in the UK.
Jul 22, 2014 | Denon Audio Players & Recorders
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Protect light on bass box on s101
Here is what is in the manual:
PROTECT indicator
This indicator lights red when the system
cable is not properly connected or the
protection circuit in the subwoofer (DSW-
S101) is activated
Nov 09, 2013 | Denon Audio Players & Recorders
Denon s101 fault
From the Manual:
PROTECT indicator
S101) is activated
Standby light is on but will not power,just keeps flashing up power on then go back to standby.
Try disconnecting everything from the Denon including the power. Leave it off all night. Next morning plug in the power only and see if it will come up ok. Then power down (into standby), connect the other stuff and power on.
Feb 10, 2010 | Denon DVD-2500BTCI Blu-Ray Player
TV switches itself off after 1 minute standby flahes red to green
there seems to be a possibility that your ballast might defective.. i recommend you replace it. It might not have enough voltage to keep up with the new lamp
Jul 02, 2009 | Sony Televison & Video
Jun 27, 2008 | Denon AVR-1705 Receiver
Denon S-101 System Logo
273 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
