Question about Linksys Wireless-N WRT150N Router
I have a linksys wrt150n wireless router
It used to work and now I need use my internet modem and cable to connect to internet. I have tried resetting the linksys box,etc and still no luck. I need wireless--please help.
  • 4,889 Answers
Do you see the wireless light blinking? IF yes then there are a few things you should try.
1. Factory reset. Press and hold the reset button for 10 seconds then reconfigure your router and see if it resolves the issue
2. Firmware update. Download the firmware update and then access you router and click on firmware update and browse for the update you have downloaded(you have to extract it first just in case its zipped) Hopefully that will do the trick.
If none of the these work then its a hardware fault and you will have to get your router serviced!
Sai.
Posted on Mar 01, 2009
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
MY LINKSYS WRT150N ROUTER WAS CONNECTED TO THE MODEM VIA CABLE.IT WAS WORKING NICELY FOR WIRELESSLY CONNECTING TO LAPTOP AND IPOD AND ANOTHER LAPTOP/DESKTOP WITH A ASUS USB ADAPTER.THE...
Try turning off the power wait for 30 secs and reconnect the power and check if the LEDs light up again.
IF NOT THEN -
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 06, 2011 | Linksys Wireless-N WRT150N Router
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
Linksys WRT150N is connected to the internet via cable modem, but the wireless router shows no internet connection and I am unable to log into teh router manually?
Reset the router for 30 seconds. Then power cycle the router and modem.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 01, 2010 | Linksys Wireless-N WRT150N Router
How to fix the router? it always says Router not found... I've been doing the steps again and again but it didn't work... I've already reset the router..still router not found... grrgrrrrr...my router is...
Are you trying to connect through wireless or using an Ethernet cable? If you've just pulled the modem out of the box, you shouldn't be able to connect and configure through wireless. You will have to connect up an Ethernet cable, go into a Internet browser, and type in the IP address of the router. From there, you can configure your router providing you have the login details of the router
Apr 15, 2010 | Linksys Wireless-N WRT150N Router
My linksys WRT150N router won't recieve internet signal from my dsl modem. The router sends out a signal to my lap top, but no internet connection can be made.
Try connecting your laptop directly to the dsl modem to make sure that it is working correctly.
If the dsl modem is working correctly then:
1. Turn off the power on the router and dsl modem.
2. After about 2 minutes, turn on the dsl modem.
3. Wait another 2 minutes, then turn on the router.
Occasionally you need to do this to get them back in synch. If this doesn't work you may need to use the software utility to reconfigure the router.
Dec 27, 2009 | Linksys Wireless-N WRT150N Router
I have an internet connection through my desktop that is plugged into a cable modem but when I run the Linksys Easy setup software it says it can't find a internet connection. I have turned off my Norton...
Make sure connections are correct. Cable modem to router with Ethernet cable. then connect router to computer with another Ethernet cable and see if it works.
o this:
1. hut down computer, modem and router.
2. put them on in this order waiting 1 minute between each.
---cable modem
---router
---computer
you also have to check that the router is set up as dhcp
Dec 26, 2009 | Linksys WRT150N Wireless N Router -...
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
208 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
