Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
USB Mouse and Keyboard Freezing
I recently updated my bios on my Asus M2N-SLI motherboard in order to accomadate a new AMD 7750 Black Edition Processor.. The bios update went smoothly and everything seems fine except for the fact that both my USB mouse and Keyboard freeze when I try to use them. I have another ps2 keyboard which works perfectly although I don't have a ps2 mouse to test with.
Both the USB keyboard and mouse work fine in safe mode which leads me to believe that I have some sort of driver issue with the USB ports? I have formatted windows and tried various versions which I made in nlite including a revision with no service packs and one with SP3.
Any ideas as to what could be causing this or how I could fix it?
tom19511
  • 1601 Answers
SOURCE: Serious problems with an Asus M2N E SLI motherboard.
try the board with out memory and hard drive.
Do fans run?
Anything?
Posted on Nov 22, 2007
sodeep
  • 3267 Answers
SOURCE: Usb keyboard no longer recognised during boot process
Restore your PC before the BIOS update. BIOS updates are not required until & unless you face problems while running a software and it will prompt you for BIOS update. Do this update if its vital othewise do not intergere in the BIOS. I faced the same problem and after unistalling all drivers and again reload the original driver from MB VD slved it. Another thing in BIOS is USB setting at high-spped & full-speed. Try changing those settings and retry. Mine worked!...sodeep
Posted on Mar 22, 2009
byteguy
  • 2229 Answers
SOURCE: Asus M2N-E SLI
In my experience, there are some fans that are loud. It could be bad bushings or possibly a fan that is out of balance. The Cool and Quiet utility will not solve that problem.
Are you sure it's the CPU fan?
If the computer (or it's parts) are less than a year old, they should be under warranty.
If it's the case fan, I'd replace it with either a new single-speed fan or one that has a variable speed adjustment.
Posted on May 27, 2009
mbase213
  • 728 Answers
SOURCE: BIOS voltage settings for ASUS M2N-SLI Deluxe 570
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Posted on Oct 22, 2009
johnhercus26
  • 104 Answers
SOURCE: hi.i have windows vista ultimate and an asus
this is a compatibility with vista issue with the devices not a mobo problem im affraid
Posted on Jan 17, 2010
Will an Asus m2n-e sli run an AMD Athlon X2 7850 2.8GHz am2+
As you can see here
http://www.cpu-upgrade.com/mb-ASUS/M2N-E.html
if you have the correct BIOS, yes.
Dec 24, 2010 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
have you tried removing all other hardware like your graphics card and all other peripheral cards even memory and booting to see and eliminate all other components?
Nov 21, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
Asus M2N-E SLI
Apr 06, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Asus |M2N-E SLI Reeboot issues
Hey, I own the same motherboard and I don't have your problem.
I would suggest trying to update the bios, i think its more of a bios problem / motherboard issue, not windows related.
you can get the newest bios from http://support.asus.com/
Oct 20, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Vista ultimate - Second card doesn't have enough resources???
thats 64 bit for ya.. welcome to buggy driver "if they support (beta)it"..
chipset, then video driver.. also vista has UAC issues. right click install as admin. good luck (i dont like vistuh)
Nov 26, 2007 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Do fans run?
Anything?
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
477 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
