Question about Panasonic DMRES20D DVD Recorder
Cant record sky
I would like to link my freeview dvd recorder up to my sky box hd so i can record sky is this possible i have tryed but as it is always looking to give you freeview firstly i cant think how to ether by pass this or is there anopther way its a sky HD box i have and a panasonic HD tv
i know with a normal dvd recorder there is no freeview so this is usualy easy as this is the instructions you receve
    Problem Solver:
  • 5 Answers
Connect it to the box with a SCART lead, select A1 or A2 with the channel up / down buttons and away you go
(select A3 if you use the phono connectors under the front panel)
Posted on Mar 05, 2009
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Can you show me how to connect up the scart and aerials up to the following so they operate correctly Samsung PS42C450 42-inch 600Hz Widescreen HD Ready Plasma TV with Freeview SAMSUNG DVD-SH893M 160GB...
hello firstly scart lead from sky box to tv1 in) this is at the top there are two AV inputs ,,,on the bottom AV slot this is where your DVD conects too).iff you are using sky you will not need aerial in back of tv as this is for analogue use such as indoor antenna or outdoor antenna or iff using horizon the scart lead will suffice for all goodluck
Mar 19, 2011 | Samsung PS42C91HDX 42 in. Plasma TV
I have a Pioneer DVR5100H which was set up to record Analogue programs - can I change the set up to accept digital programs. I have tried auto setup but it doesn't pick up any programs?
You can't record digital programmes with this recorder unless it is connected to a digital tuner, e.g. a Freeview box or Sky digibox. This recorder has a built in analogue tuner which allows it to record analogue transmissions. Recorders which can record digital transmissions have a built-in digital tuner and usually have a DVB logo (actually looks more like DV3) on the front.
If you want to record digital programmes using this recorder, you need to connect it to a Freeview or Sky digibox, preferably with a scart cable. It is not sufficient to connect it to a TV with a digital tuner or built in Freeview as the player does NOT record directly from the TV, it must be connected directly to the transmission source. A basic stand-alone digital tuner (Freeview box) can be bought for as little as £10-15.
Regards,
BElectric
Nov 18, 2010 | Pioneer DVR-5100H DVD Recorder
I HAVE A DTV WITH BUILT IN FREEVIEW AND A DVD RECORDER WITH BUILT IN FREE VIEW, BUT CANT SEEM TO GET A GOOD PICTURE TO RECORD OFF THE TV. ANY IDEAS?
You could try an antenna booster but if the picture is still snowy you wont get much of an improvement. Also make sure that you have a HQ yagi array on top of your house, direction and height location can make a huge difference.
I suggest ditching the freeview and going for SKY or Virgin media
Dec 16, 2009 | Televison & Video
I have a samsung42 inch flat screen and a dvd and a sky plus box and avhs recorder could show me how to do the set up connections please
If you have a blueray or HD DVD player I would connect using a gold plated HDMI cable from the TV to the DVD, make sure that you buy the correct HDMI version for your TV. If you don't have a HS DVD player recorder then use a HQ SCART as below.
Most SKY+ boxes still have a SCART connection I suggest that you buy a HQ gold plated ribbon connector to connect the SKY to one of your AV (audio visual) channels. The benefit of using SCART is that it will autoselect the AV channel when SKY is taken out of standby.
You will not need to connect using co-axial cables these are pretty much redundant now as you can get all your channels through your SKY dish.
Also if you live in a poor reception area and your TV has freeview built in SKY is your better option.
Nov 22, 2009 | Televison & Video
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
I have a 32in lg tv with one HD input. Also i have a sky hd box. also there is an lg hard drive dvd player/ recorder and also a philips 6510 home cinema player with speakers. what is the best way of...
I would use the Sky box manuals recommendations for connection as this usually gives the best performance especially if you wish to record from Sky to the DVD recorder.
Oct 30, 2008 | Philips Televison & Video
How to connect to sky
The Sky Box should have 2 scarts on the back, one to go into your TV and one to go else where. One of them goes into the back of your DVD recorder.
You can then source and record through the DVD.
May 07, 2008 | Lite On LVW-5115GHC+ DVD Recorder
Connection Nightmare
try here in this forum http://radioandtelly.co.uk
they will give you some ideas t oconnection set up .
riz.
Nov 02, 2007 | Daewoo DVDRW11 DVD Recorder
Panasonic DMRES20D DVD Recorder Logo
207 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
