98 V70 air conditioner works for 10 minutes then no more cold air. Shut A/C off for 15-20 minutes then back on and it will blow cold air for 10 minutes and then air turns warm again. Recharging system didn't solve problem.
I had exactly the same problem. When your engine is cold and off check the gap on your ac compressor with a feeler gauge, it should be between 0.3 and 0.5mm. If it is larger you need to re-shim which invloves undoing a nut on the end off the compressor and removing the clutch plate, then removing the appropriate shims (look like washers) then replace. The reason it blows warm after 10 minutes or so is because the ac compressor gets hot and the clutch gap gets too large for the electro-magnetic clutch to engage. Some people would say that you need a new compressor but all you need to do is a re-shim.
SOURCE: 1998 Volvo V70 A/C intermittent
I AM AN ASE CERTIFIED VOLVO----MASTER TECH AND YOUR PROBLEM W`HICH IS COMMON ON ALL 850,S ANDS70,S THE PROBLEM IS PROBALLY AT LEAST 70% DUE TO AN AIR-FLOW RISTRICTION TO THE CONDENSOR FIRST IS SYSTEM AT FULL CHARGE LOW SIDE 25-33 PSI AND YOU AND I REPEAT ONLY CHARGE SYSTEM ON THE LOW SIDE THERE IS NO AND I REPEAT NO HIGH PRESSURE CONNECTOR AND WHAT I WOULD DO IS RUN AGOOD THICK WIRE FROM A/C COMPRESSOR AND A 30 AMP FUSE FROM A CIRCUIT LIKE THE HEATED SEATS FROM INSIDE THE CAR WITH A TOGGLE SWITCH AND A THERMOMETER IN CENTER AIR DUCT AND MANUALLY SHUT THE SYSTEM DOWN IF IT FALLS BELOW 40 DEGREES AND WATCH THE THERMOMETER EVERY 7 MINUTES AND THE MAIN PROBLEM IS THE ENGINE FAN CIRCUIT I HAVE DONE DOZENS OF THESE AND THE PROCEDURE IS WHAT I WROTE
I checked the gap and it is in fact larger than .5 mm
Do you have to remove the compressor to make the shim adjustment? Looks pretty tight in there.
Thanks
