Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
Posted on Mar 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fridgidaire Gallery Series Dishwasher Leaks from bottom
I have a Frigidaire Gallery Series Dishwasher that leaks at the bottome right corner and puddles up on my hardwood floor.
Anonymous
Level 3:
  • Frigidaire Master 43,501 Answers
  • Posted on Sep 29, 2010
Anonymous
Frigidaire Master
Level 3:
Answers
43501
Questions
0
Helped
10842767
Points
101584
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
wre
Hey guys....My Fridgidaire Gallery dishwasher is locked closed and has pf code on it....now what?? Thank you!
Cutting the power for 5 minutes, usually releases the lock.
Your electricity voltage is too low.
Frigidaire Dishwasher Error Code = PF Check / Repair / Solution = A power failure has occurred. More than 10% of power has dropped to the unit. Check house wiring.Feb. 18, 2016
Frigidaire Dishwasher Error Codes - What To Check - How To ...
How to Fix a Frigidaire Gallery Dishwasher With a PF Code ...
https://www.hunker.com > ... > Dishwashers
Step 1. Check the other appliances in your kitchen for power interruptions, as an indicator of what might have caused the "PF" error for the Frigidaire dishwasher.
FIXED - PLD2855RFC0 Frigidaire - PF Error Code ...
https://www.applianceblog.com > mainforums > threads
May 22, 2013 - I'm getting the "PF" error code at the same spot... ... Brand: Frigidaire ... verified the heating element has excellent continuity and ... What fixed it for me: I replaced the circuit breaker of the dishwasher on the outside power panel. ... When the door is closed, it gives a PF error and flashes a few times. If I open ...
Frigidaire Dishwasher Error Codes Explained
https://howtofixit.net > frigidaire-dishwasher-error-code...
Feb. 10, 2020 - This is a guide on what Frigidaire Dishwasher error codes are and what ... To fix this error code try opening and closing the dishwasher door to reset the cycle. ... When the i30 error pops up it is saying that the bottom pan has a leak to it. ... that you will run into will be power failure, this is under the PF code.
Mar 03, 2021 • Dishwashers
Frigidaire gallery fghd2455lf leaks from bottom of door
Thank you for your post, Jacques Lanthier!
From what you have described it sounds like you could have a loose or bad gasket on your Frigidaire dishwasher. Typically, to clean any seals you would remove them and wipe them off with a rag and warm water. If you continue to experience an issue with water leaking I would recommend replacing the gaskets. I hope this information has been helpful. -Matt
Frigidaire dishwasher leaks from motor
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
1helpful
After the cycle starts, water leaks out of the bottom of the machine and into the basement
I would call for service. many probabilities and none are good. it is fixable but for a diy'er it could get to be a bit much.
1helpful
Dishwasher leaks from the bottom of the dishwasher what causes this?
Leaking Dishwasher
heatman101
1helpful
Water leaking on the floor at the door.
frigidaire models usually leak water at the top of the door and water enters in the door through door latch.2 fix this u can insert a double sided sticking tape behind the tub seal at the top so that door top sits tight against the top part of seal.
also u can remove the front door panel 2 c if water ia jumping out of tub at the bottom at lhs and rhs corners.if thats the case pull out the door seal and insert it back stretching it little bit and leaving some of it extended at both bottom corners so that it can stop the water from splashing out.
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Cannot clear PF light flashing on frigidaire dishwasher
Frigidaire dishwasher will not work at all it has PF blinking
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
john h
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
