Question about DeLonghi Dehumidifiers
Fan stops turning and overheating smell
At irregular intervals the fan just stops turning followed by a burning smell and it shuts down. It has done this a few times and has worked for weeks between incidents. I have taken it apart and cleaned everything I could but it still happens. Is there a part I can order and perhaps change myself? I appreciate your help with this.
Regards,
Steve Pion
3 Suggested Answers
  • 220 Answers
SOURCE: Kenmore dehumidifier 54501: Fan does not work. I
Call sears see if the compressor is under warranty
Posted on Sep 01, 2009
  • 4736 Answers
SOURCE: 2 yr. old. worked great.
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Posted on Jun 02, 2011
When turn off. makes a humming sound. compressor seems to be running.
Have same issue with 3 year old Frigidaire dehumidifier purchased in 2012. Must unplug to stop compressor running with power switch turned off. Unit gets hot and smells. Unplugging creates arcs at outlet since unit is pulling a lot of power. Plugging back in after some hours will make it appear to run normally and again remove moisture but it will not shut off when the fan goes off (humidistat bad?) and the set-point is reached. Cannot leave plugged in due to safetty/fire/overheating concern. Have not found answer on this forum or any other so far.
Sep 15, 2013 | Frigidaire FAD704TDP Dehumidifier
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Jun 02, 2011 | Dehumidifiers
My dehumidifier smells like its burning when I turn it on. It is about 5 years old, does this mean I need a new one?
Judy, the fan motor or the compressor motor may be failing. It's cheaper and less of a hassle, to replace a 5 year old unit, than it is to repair it.
Jun 02, 2011 | Whirlpool AD25BSR Dehumidifier
No water collecting allso burning smell also it do not sound lik compreser is kiking on
If you haven't already, turn the Master ON/OFF Switch to OFF and unplug the unit. Obviously, if you're getting a burning odor from the dehumidifier, something is terribly wrong. Since there are no belts on the motor or fan of the unit, the compressor may have burned up. In which case, the cost of repairs would almost or be equal to, the cost of a new unit.
I'm sorry, I wish I had better news for you.
May 24, 2011 | Dehumidifiers
I just replaced the thermal fuse as described by several of your people for a fan motor on a Kenmore dihumidifier 580.54701400. The unit ran fine for about an hour and then stopped with a burning smell...
Your call on the $39 replacement replacing the whole thing.
did the TCO you put int have the same specs (temperature) as the one you replaced? I've replaced a lot of these and they'll keep running.
The burning smell points to a failing coil which creates the heat which opens the TCO. you already know how to get the motor coil out so I think the $39 options is better.
Oct 09, 2010 | Kenmore 54701 Dehumidifier
The unit begins and after a short time the unit stops.
it sound like the unit is very low on r134a refrigerant and in being so the compressor is overheating and the thermocouple sensor on the compressor body is shutting off power to compressor to keep it from burning up
Jan 17, 2010 | Frigidaire FDL25P1 Dehumidifier
The fan inside is having a hard time rotating...starting to smell. what gives?
If the fan motor is quite hot to the touch when it is running and the smell is like something burning and the fan blade isn't rubbing on the housing then the fan motor bearing are most likely worn out. If that is the case then the fan motor is bad and needs to be replaced.
Nov 17, 2009 | LG LHD65EBL Dehumidifier
Compressor runs, overheats and shuts down..fan does not run...
I have had the same problem. Following the advice of someone on these pages I opened the machine up and checked the fan with a meter. On my model (the 404) it has two settings so two leads; one seemed okay, the other was dead. I checked the circuit where the fan connector plugs in and I got that both speed settings were supplying plenty of juice. Apparently the fan motor is dead. A replacement runs $79 at http://www.appliancefactoryparts.com/. I ordered one; we'll see what happens.
Apr 11, 2009 | Goldstar DH504EL Dehumidifier
Doesn't want to stay on...
Most likely the fan motor has broken. Without the fan, the compressor will overheat. There is a safety device inside that automatically shuts off the compressor to keep the overheating from destroying it. Check to see if you can feel air movement in the front or back of the unit while it is running. If not, then the fan motor has definitely broke. I had this exact problem on mine.
If you take the unit apart, you will find a parts list inside the unit. It will be inside a small plastic pouch. You can order a new fan motor from Sears. The cost is $30 plus shipping.
You will have to move the condensing coil in the front out a bit in order to exchange the motors. Just be careful not to break any of the copper lines. They are copper so they will flex quite a bit without breaking. Still, use caution. If you break the lines, all the refrigerant will leak out and your unit will be useless.
Sep 01, 2007 | Kenmore 54501 Dehumidifier
Dehumidifiers Logo
57 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
