Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
When I look through the viewfinder of my camera I see blue streak
I have recently had my minolta camera fixed and now when I look through the viewfinder on the camera there is a blue streak in the corner of the viewfinder.It is on both sides of the veiwfinder. What causes this to happen ? It didn't do this before I had it fixed. will this show up on the pictures I take?
This isn't really a solution, but when I check "I have  similar problem", it takes me to a different page all together. The first time I heard about a blue glow in the viewfinders of late-model Maxxums was in reading an eBay guide written by J.D. Katz. I didn't really believe him until my own Maxxums started doing it. Apparently Maxxums 3, 4, 5, GT, QTsi, STsi, HTsi, XTsi and probably the 50 and 70 are susceptible. All were assembled in either Malaysia or China and all have penta-mirror viewfinders. Both my Maxxum 5 and my XTsi just recently started doing it: the 5 has sapphire-blue streaks on either side of the viewfinder; the XTsi's viewfinder has just a faint blue haze. Probably some coating on the glass inside the viewfinder is breaking down with age. It's a shame because they are otherwise excellent cameras. While it is an annoyance, it is confined to the viewfinder and should not affect the images taken. Probably won't have much luck getting Sony to do anything about it either, since they're film cameras and they're getting old....
Posted on May 29, 2009
D90 eRR msg
Have you tried using a different lens ?
Sep 10, 2017 | Nikon D90 Digital Camera with 18-105mm...
Viewfinder shows only streaks
if the pictures are like that as well, chances are your CCD sensor is on the way out. if only on the viewfinder (so pictures are OK) it may well be the display of the viewfinder that is also known to give problems although much less... however, if the viewfinder is the problem you should be OK to use the cam. in case you did not replace the CCD, i would be careful spending any money. i am now trying to get the 3rd CCD in my cam... they are really a problem.... I have 2 of these and they seem to keep on failing on the CCD's. pity, since i really love this camera...
ton
Sep 12, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Minolta Z1 Digital Camera
I followed the directions that were posted on the free suggestions on your site:
Turn the camera on in viewfinder mode. Turn it off and turn it upside down in your hand.
Smack the bottom of the camera several times with your other hand.
Turn it back over and turn it back on. It took me three tries, but voila, on the third try, it worked!
I could see through the viewfinder again.
Jan 11, 2009 | Konica Minolta DiMAGE Z1 Digital Camera
Minolta Dimage A1 viewer is BLACK
you will have to replace the CCD chip alone. it is worth fixing. you can go ahead. but do it with some authorized service center.
Jan 06, 2009 | Konica Minolta DiMAGE A1 Digital Camera
Minolta Dimage Z1 power quiting
Your power board most likely has a short. You could send it in to mackcam.com for an estimate
Dec 31, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Viewfinder on Minolta Z1 Dimage doesn't work
I had the same problem. I got it to work by adjusting the viewfinder focus back and forth, this is the little nob to the left of the viewfinder. Might work for you?
Nov 29, 2008 | Konica Minolta DiMAGE Z1 Digital Camera
Konica minolta dimage z6 problem
Sony handle repairs to Konica Minolta gear (I think) good luck.
Feb 10, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Minolta dimage 7i powers up all functions but lcd and viewfinder are blank
You both are in luck. This sounds like a defective Sony CCD issue. Sony will fix your Minolta camera for free (with free shipping) regardless of warranty. You need to do this before March 31, 2008 so get going! See this link:
http://esupport.sony.com/US/perl/news-item.pl?template_id=1&news_id=131#
The Dimage models that Sony is accepting for the recall repair are:
Dimage 7HI, 7I, A1, Xi, F300, XT, X20, S414.
Oct 27, 2007 | Konica Minolta DiMAGE 7i Digital Camera
Wierd Images in Viewfinder and Photos
sounds like ccd sensor faulty.the only thing you can try as you say fault happened when lens got jammed is to reset camera by removing batteries for a few secs and reinserting,if this does not work will have to go to service.,
May 11, 2007 | Canon PowerShot S1 IS Digital Camera
Viewfinder dead
It's a very common problem which seems to eventually affect all A1's and A2's eventually. My sixth one failed yesterday.
The fault is a tiny crack on an internal flexible circuit board, the bad news is that there is no easy or lasting fix.
The best you can do is to undo the two small screws underneath the viewfinder and remove the lower cover. You'll see the flexible pcb immediately and the break occurs in one or both outermost electrical tracks below the blue or yellow tape in the lower r.h. corner. If you turn the camera on and gently manipulate the pcb you can often get it to work again, but to prevent it reoccurring too quickly you'll need to fix the viewfinder in the lowered position permanently. Unfortunately, a knock can just as easily stop it from working again and the damage does eventually progress to other electrical tracks.
The only proper fix is to replace the pcb, but it's no longer available and you have to dismantle the camera completely to do so and it's not an easy job. If you can find an old stock replacement pcb then you'll see that KM never resolved the issue: it's exactly the same as the old one and will fail in time. I found this out the hard and expensive way.
Aug 14, 2006 | Konica Minolta DiMAGE A200 Digital Camera
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
369 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
