Question about Apple iPod MA446LL/A MP3 Player
My ipod is showing low battery, but when I connect to charge it, it's not charging....
    President:
  • Apple Master
  • 688 Answers
Your Problem may be the Battery needs to be replaced.
Go here to find one...Click
if you ipod them shows it's it's charging you should be good
Posted on Mar 02, 2009
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
Ipod wnt charge
Is the iPod's battery so low that it can't communicate with the computer? And what do you want to charge the iPod with? A wall-socket or with the USB If you have access to a wall charger, try to use that one. You could also ask a friend with an iPod if you can charge it in their charger. I had once that my batteries were so low it showed the "Connect to Power" screen and shut off due to inactivity, also if I tried to charge it in a dock. I tried to use another dock linked to an amplifier and it turned on immediately. Furthermore, what generation iPod are you using?
May 24, 2010 | Apple iPod nano
IPOD APPLE 80GB STILL NOT CHARGE OVER 8HRS USB WITH COMPUTER
try getting a usb wall plug in and charging it that way you computer may not be able to supply enough power either that or you ipod is deffective and has a power supply issue if this is the case i recomend either getting a new one or getting it fixed
Jan 05, 2010 | Apple iPod MA446LL/A MP3 Player
I have 30 gb ipod when my ipod is completly down i cant charge my ipod it show low battery i keep for charge for 2 hours still it does not get charge
The 5th Generation iPod (iPod video) were made and sold in 2005. Batteries inside iPods tend to last 2 to 3 years (4 if you hardly use them). It could be time to replace the battery inside your iPod.
Apr 13, 2009 | Apple iPod MA446LL/A MP3 Player
Low Battery
In this case whct you can do is to connect it to your Desktop computer ( Connect the ipod to USB Port at the rear of your computer and charge it for at least 12 to 16 hrs
This should resolve the issue if it not a problem with Battery..
Pls reply..
Jan 11, 2009 | Apple iPod nano
My ipod wont charge
This is either a bad battery or bad battery connector Hope it just Battery.
Jan 07, 2009 | Apple iPod MA446LL/A MP3 Player
I pod problems
Hi
I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
Dec 20, 2008 | Apple iPod MA446LL/A MP3 Player
80GB video ipod is not turning on.instead the apple symbol blinks
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
Dec 19, 2008 | Apple iPod MA446LL/A MP3 Player
Apple ipod not getting charged
First, please check your connection (I'm sure you have already done this). Make sure that the cable is plugged in and working on both ends.
If that is fine, I would recommend taking it back and getting a new one. If you just recently purchased it, you should be able to return without a problem. It sounds like you might have a defective product and you don't want to get stuck with it after the return period.
Good news is that when you get the new one, if you use iTunes, it will automatically sync up and you wont have to manually load songs.
Hope this was helpful but if you still have questions, let me know.
Have a great day
Nov 13, 2008 | Apple iPod nano
Apple screen
Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge normally, just enough so that it can come on and sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, wait few minutes, charging. It should work after letting it sit plugged up to the computer.
Oct 17, 2008 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
51 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
