Question about NAD C320 2-Channel Amplifier
AUX problem between my laptop and NAD C 320BEE
The sound is coming from way back and choked when I connect my laptop via AUX cable to my NAD C 320BEE. I open the sound to full on amp and full on laptop and I can hardly hear it play. When I connect to main in via the same cable the amp acts as a monitor and plays back which makes me sure the cable is working. Is it a problem with my laptop's sound system or a problem on the amp where I input the AUX cable? Laptop's sound system is SoundMax HDAudio.
    Genius:
  • 1,175 Answers
HI...
I would check on the Soundmax software set-up on the PC and make sure that the AUX is set for a line-out connect.
Also,make sure the tape monitor isnt on ..On the amp
Posted on Mar 01, 2009
No sound from tv when connected via HDMI
some laptops can only send video through hdmi. try using a v-aux cable from your laptop to tv (if the tv has a v-aux port)
Feb 06, 2014 | Dell Inspiron 1521 Notebook
Connect imac to amplifier
e4228d3d-a132-463b-8916-f7c5307ccb67.jpgI have looked at an image of NAD rear and it has RCA type jacks. I would plug it into the AUX sockets. Now to if it will work. Plug some stereo headphones into the iMac socket. If you can hear sound then the cable you intend to buy will transfer the sound you hear to the amp. If you want to record from the amp to your computer you will need another a different input on your computer and that would need to be connected to tape 1/2 out.
Any 3.5mm socket to RCA will do, they are not expensive plenty of cheap ones on Amazon and E-Bay (image shown). You will need two if you do want to record as well.
Aug 05, 2013 | NAD Audio Players & Recorders
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
I have connected my laptop via a 3.5mm RCA cable to the Aux input of my Cinema receiver, however there is a terrible feed back sound in the speakers. Why is this ? perhaps it's the quality of the cable as...
mono to stereo juck try get some non aloyed cables also try turning the laptops sound down just so that you can hear it then use the amp to push the sound out you could be overdriving the sound
Apr 04, 2011 | Onkyo Audio Players & Recorders
Nad 712 no sound
Check to see if one of the Tape Monitors is ON. Turn it OFF.
There's supposed to be a pair of jumpers between Pre Out and Main In. Are they there? If not, install a short RCA cable pair.
May 05, 2010 | NAD 712
Screen does not light up
Hi
disconnect the power cable and remove the battery nad then press nad hold the power button for a minute. then connect every thing back and then see if the screen comes on.
in case it does not then again remove the battery nad power cable and remove the hard drive nad ram and put it back in again.
nad then check still does not work see if the screen comes on an external moniter, still if it does not come on call HP if it is under warrnty they would give you free repair.
Apr 12, 2010 | HP Pavilion dv2000t Notebook
Right loudspeaker problem
Doesnt sound like the selector as it "sometimes" works. Redo the speaker connections on the back of the amp and speakers first. If it persists, swop the speakers and cables, if the problem swops, then it could be inside the speaker or the cable, if still the same then amp has dry joints/loose connections probably
Jun 24, 2009 | NAD C372 Amplifier
How do I setup the SoundMAX device for AUX line-out?
The cable from the computer simply needs to be plugged in to the speaker/headphone jack on the computer, then run to the AUX input on the amp. Make sure the volume on the computer is set to about 75% - 90%.
Apr 07, 2017 | NAD C320 2-Channel Amplifier
NAD C740 no longer reproducing music through loudspeakers
what was your amp? ic or transistorized? the output transistor of your amp may be opened, mostly it will short but because u still hear sound, maybe open and only the driver transistor are working. replacing output transistor or IC could solve the problem.
May 14, 2007 | NAD C320 2-Channel Amplifier
NAD C320 2-Channel Amplifier Logo
298 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
