Question about Jenn-Air Attrezzi JSM900 Stand Mixer
Changed bulb and light still not working
I changed the flourescent bulb in the under cabinet lighting and the light bar still doesn't work. I replaced it with the same bulb I took out, except that the new bulb had green ends and the old one had silver ends. I put in 15W 12inch bulb and turned it in the ballast (I think that's what the part is called that they slide into) until I felt the "snap". I did not re-install the guard, but I can't see that being an issue. The unit is hard-wired and operated by a wall switch. I took the bulb out and tried turning it the opposite way, as well as flipping the bulb and turning it both ways until it "snapped" into place. Still nothing. All the other bulbs work.
  • 686 Answers
Look for a silver looking thing it's a stater it twists out counterclockwise replace that
Posted on Mar 01, 2009
  • James Chandler Mar 01, 2009
    look for a silver looking thing it's a stater it twists out counterclockwise replace that
My food disposer has no sound I need help. Could you help me?
If you open the cabinet door under the sink, you should be able to see the disposer motor. On the bottom or side, there should be a small bump that is the reset button. Push the button in and it should work again.
If it still does not work, make sure that the power cord is plugged into the outlet.
Still not working? Check the fusebox for a blown fuse or tripped circuit breaker.
One last idea: if the outlet that the disposal is plugged into is a GFCI protected plug, there will be a TEST and RESET button in the center of the outlet. Unplug the disposal cord, press the RESET button on the outlet, then plug the disposal cord back in.
Aug 31, 2015 | Food Mixers
What's wrong with it?
Switches have more than one pole. Pole to the lights work ... as does the bulb.
Either the poles to the motor or the motor windings are bad. I'd leave that to a repair shop.
Oct 04, 2014 | Food Mixers
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Nov 05, 2012 | KitchenAid Food Mixers
Under cabinet halogen lights not working
you over loaded that section power source less expensive to replace with new lights
Feb 05, 2010 | Jenn-Air Attrezzi JSM900 Stand Mixer
Teeth keep stripping on the Bosch blender.
Is there a lubrication issue? Is there a bind or load to the drive after the gears? What has changed since it worked well? P{ancake batter would not be sufficient load to eat gears. Are you changing speeds under load?
Oct 04, 2009 | Bosch Food Mixers
Under cabinet light not working
probably not defective bulbs. Flourescents use either a starter and transformer or a ballast. When lights are weak, could be either. Very simple to change too. One other thing, could be connections that go into the lamp holders. If not good connections, light will be dim. On a stretch, if unit is located in an area that us lower than about 50 degrees, this could cause them to be dim. Check ratings on ballast/ starter and transformer. Finally, if voltage is either too high or too low, this could be a dimming problem too. If it has worked in the past, and this is a current problem, then chances are it's not the voltage but may want to check it anyway to eliminate that possibility.
Feb 05, 2009 | Jenn-Air Attrezzi JSM900 Stand Mixer
Emerson MW 8115SS
Remove screws, remove cover, replace 20A 125v fuse. Should work.
Nov 16, 2007 | Food Mixers
Jenn-Air Attrezzi JSM900 Stand Mixer Logo
286 people viewed this question
Top Jenn-Air Food Mixers Experts
Oscar Netto
Oscar Netto
Dennis Boxerman
Gerry Harvey
Gerry Harvey
Are you a Jenn-Air Food Mixer Expert? Answer questions, earn points and help others
